western Posted July 15, 2017 Author Share Posted July 15, 2017 Photo's of the new [yet to be fitted] clutch hoses & end fittings. the blue connector will go to the existing flexi hose connection of pipe from master cylinder, the 2 90 degree fittings/adaptors to slave cylinder ports bleed screw end will be on a bracket on left inner wing. Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2017 Author Share Posted July 29, 2017 Well I was intending to fit these hose this weekend, but persistent rain has stopped that job. Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2017 Author Share Posted August 10, 2017 Finally got time to get these fitted today, all went together very well. the new hoses are well clear of the exhaust, made a bracket for the bleed screw end, it's just a temp one for now, probably make another to drop the bleed screw end down a bit lower, but as it is now, doesn't touch when bonnet is shut., so quite happy with the result. 1st pic hoses at slave cylinder end, bleed hose is upper. 2nd pic homemade bleed point bracket, hose come up under the air intake trunking & behind the washer tank. 3rd pic pipe from master cylinder through adaptor to slave cylinder, viewed from under vehicle, exhaust downpipe on left 4th pic view of hoses from above, heater box on right. 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 10, 2017 Share Posted August 10, 2017 Very nice , Ralph 1 Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 10, 2017 Share Posted August 10, 2017 Ralph, could you tell us the cost and do you know if llama might be happy to produce a few more? Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2017 Author Share Posted August 10, 2017 Total cost was £72 inc VAT, David just put misc hoses & fittings as discussed on the invoice/receipt paperwork, I discussed it over the phone, we decided on the end fittings/adaptors & hose lengths, I'm sure David would produce some more but you'd have to discuss with him your exact requirements. Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 11, 2017 Share Posted August 11, 2017 It's a good solution. I think I will do the same to mine, though I'll site the bleed nipple on the clutch pedal box so that I can open or close it while watching the Ezibleed reservoir level. That's assuming I don't fit the ZF, which is increasingly unlikely. Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2017 Author Share Posted August 11, 2017 I didn't test if the long bleed hose would fit at the pedal box, might give it a try over the weekend, it's only 1 bolt to undo. I've got a one man bleed kit, so about 8 strokes on the pedal left some fluid in master cylinder during bleeding, Quote Link to comment Share on other sites More sharing options...
western Posted September 3, 2017 Author Share Posted September 3, 2017 only adjustment so far has been to lower the bleed screw fitting in the bracket, clutch operation seems to feel better after fitting the hoses. Quote Link to comment Share on other sites More sharing options...
