Part number for Rear BOGE Bottom joint
1986RRCV85SPD
I'm presuming you mean the one that goes into number 9 - bracket rear axle fulcrum - in this link?
http://new.lrcat.com/#!/1230/69277/69610/5680
If that's the one then it's:  http://www.ebay.co.uk/itm/Range-Rover-Classic-Rear-A-Frame-Ball-Joint-ANR1799-/201470043460?hash=item2ee88ce544:g:ynsAAOSwZVhWTkgq
Common source of a clunk when pulling away from standing & when taking the foot off the loud pedal for slowing or gear changing. When they start to clunk they're well worn! Check by using a lever between the diffhousing & the a-frame. Should be little or no movement.
The balljoint is available on its own as above or also pre-assembled into the fulcrum bracket : http://www.paddockspares.com/fulcrum-bracket.html
They can be a bit awkward to get the pin end out of the bracket on the axle (on mine the axle bracket is part of the axle & not removable), but the fun starts when you try & remove the balljoint from the fulcrum bracket. Don't even think of trying to do it on the vehicle, remove the fulcrum bracket. The ball joint is pressed into the fulcrum bracket & after you've removed the bolts you can either use a press to remove it & press the new one in OR batter it out then use longer bolts or threaded rod to wind the new one in. They are VERY VERY tight & if you don't line the holes up to get the bolts in then you have no chance of just twisting it a bit once it's in. I've done two & the first was by the batter method & the second with a press of the bottle-jack-in-a-frame variety(which I'd treated myself to for another job)
Batter method here: https://www.landyzone.co.uk/land-rover/a-frame-balljoint-renewal.110342/
Edited by paintman
