Chambo110 Posted February 13, 2017 Share Posted February 13, 2017 Hi fellas i have very slowly changed my old knackered tbox for a re con one. I figured while it was out I would do the rear crank oil seal ( 200tdi) and the clutch, bearing, fork and other bits in the area. When tbox was on garage floor, everything moved as supposed to. Diff lock went through all 3 positions. ( from Ashcroft site) I understand left or 10 o clock position not used. When re assembled it still works at 12 and 2 o clock position . And diff lock works. Problem is, hi low , when on floor it moved from low to neutral to high with a pair of grips. But now it's back in truck and mated to the lt77 I can get it to go from low to neutral and back but it seems very hard/ impossible to get into high. I don't want to force anything and break something so is there something I did or didn't do when mating to the lt77 and/or putting back in vehicle? thanks in advance mark Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 13, 2017 Share Posted February 13, 2017 Is the engine running/can you roll the vehicle back/forward? If you're unlucky, the mechanism can be out of alignment when stopped, and a very small amount of road speed can help to get into low/high Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted February 13, 2017 Author Share Posted February 13, 2017 Hi cheers for reply. Engine does run. No floor at the minute but I could move it a little I guess . Will try tomorrow thanks any other thoughts? Quote Link to comment Share on other sites More sharing options...
neil110 Posted February 14, 2017 Share Posted February 14, 2017 (edited) Mine is similar, I knock the T box into neutral when parked at Tescos and the like, just to slow the thieves down a fraction. Sometimes when I return it will not go back into gear at all, until I put the main box in gear and very slowly lift the clutch, whilst maintaining a gentle pressure on the selector lever, then it goes in quite nicely thank you.It is probably down to the gears not being aligned so they cannot mesh until everything is turning Edited February 14, 2017 by neil110 Quote Link to comment Share on other sites More sharing options...
bodumatau Posted February 16, 2017 Share Posted February 16, 2017 (edited) I always "feel" the transfer box into high or low with the clutch, without doing this you run the risk of it not quite going in and damaging itself when it "jumps" out. so I have just made a habit of always feeling it in, select 1st or reverse, pop it out of the current hi or low, then push it till you feel resistance in the desired hi or low, then let the clutch out till it just just starts biting and immediately depress the clutch again while pressing the gear lever and it slips in beautifully, once you have done that you KNOW it won't slip out with a bang and you can give it horns confidently. Edited February 16, 2017 by bodumatau Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted February 16, 2017 Author Share Posted February 16, 2017 Busy with work so not had a chance to try yet but last question from a new defender driver. it's been off the road "not off-road " since I've had it. Am I correct in thinking it stays in high for normal road driving? thanks Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 16, 2017 Share Posted February 16, 2017 Yes, high for normal driving, low for when you need to crawl. Diff lock once you are on a loose surface, and wheel could spin up. Quote Link to comment Share on other sites More sharing options...
neil110 Posted February 16, 2017 Share Posted February 16, 2017 Worth watching this video. 1 Quote Link to comment Share on other sites More sharing options...
