Stretch 123 Posted February 14, 2017 Share Posted February 14, 2017 Just had a new screen fitted and the heated screen is not working have checked the fuse Nd it's fine , the screen that came out was not the proper screen for the model discovery mk 2 td5 51 plate Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 14, 2017 Share Posted February 14, 2017 Take it back to the fitter? Could be as simple as not fitting the connections back on, but that is their problem. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 14, 2017 Share Posted February 14, 2017 55 minutes ago, Stretch 123 said: Just had a new screen fitted and the heated screen is not working have checked the fuse Nd it's fine , the screen that came out was not the proper screen for the model discovery mk 2 td5 51 plate There are two of them, one for each side... if the plugs are well connected rule out the relay(R8) too Quote Link to comment Share on other sites More sharing options...
Blanco Posted February 14, 2017 Share Posted February 14, 2017 Also don't forget that the front screen operation is enabled or disabled in the bcu , might just need toggling on. Quote Link to comment Share on other sites More sharing options...
