FTC951 OIL SEAL size issue for 89 RRC rear axle
SteveG
I went to assemble my rear axle, but when it came to fit the stub axle, there's an issue with the size of the oil seal. It's od is ~46mm, but the hole in the rear of the stub axle is ~51mm...
2E150E80-A89C-40C8-A092-A96D9E7A7AB6_zps
The parts book lists the seal as - FTC951 OIL SEAL, but on all the parts sites this is superseded by FTC5268.
Any ideas on correct part no.?
Thanks, Steve
7A7E0C7F-0A18-4143-8A8C-E1E564A4787E_zps
No response, so I assume I haven't made a stupid mistake. I'll pop by my localish LR parts specialist with the stub axle and see what they come up with. Failing that I'll order a couple of oil seals online with the correct OD & ID dimensions.
Cheers, Steve
Thanks for looking Ralph. I noticed in the parts book, that on the front axle the stub axle and swivel ball oil seals both have different numbers. I'll have a look at their dimensions tomorrow and see if either of those would fit too.
Cheers, Steve
  • Like 1
I can only go by the fact that they came out of the rear axle of an 89 range rover classic. Although it's impossible to tell, going by the bolts and the mud shield it didn't look like the stub axles had been taken off before. Certainly the hubs had been off and the bearings changed at least once. (By a ham fisted or time pressed mechanic ;) )
cheers
steve
1 hour ago, Bowie69 said:
Can you read the numbers off the old one that came out?
Can just order from a bearings & seals place then...
In hindsight that would have been a good idea when I stripped the axle a few months back. ;););)
Not a problem though, I'll soon sort it out.
cheers Steve
