Madcowz Posted February 22, 2017 Share Posted February 22, 2017 I've recently bought an X-Eng/Foundry Gear lock for my 200tdi/R380 One Ten but can't fit it. I've spoken to them about the issue and they say that the transfer lever is bent and this is what is causing the issue. Looking at it, it looks normal to me but what do I know (very very little)... So I've spoken to someone today who says I may have a disco box in there and not a Defender one. Is it possible to tell from the picture if I have a Disco or Defender box and is the lever "normal"? Thanks, Heds Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted February 22, 2017 Share Posted February 22, 2017 I thought the levers were much the same. Yours however, has definitely been 'adjusted'. Quote Link to comment Share on other sites More sharing options...
Boris113 Posted February 22, 2017 Share Posted February 22, 2017 Not sure of the differences between Defender and Disco transfer boxes but a Defender transfer box lever is normally straight, or at least the ones I've seen are. Off topic but whats the device surrounding your handbrake lever? Quote Link to comment Share on other sites More sharing options...
western Posted February 22, 2017 Share Posted February 22, 2017 90/110 transfer lever is straight. Discovery is straight too, http://www.albrit.de/epc.cfm?PAGE=P01035&CAR=L4&SPRACHE=EN reckon yours has been adjusted somewhat. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted February 22, 2017 Share Posted February 22, 2017 1 hour ago, Boris113 said: Not sure of the differences between Defender and Disco transfer boxes but a Defender transfer box lever is normally straight, or at least the ones I've seen are. Off topic but whats the device surrounding your handbrake lever? Looks like a handbrake lock with a pin to stop the handbrake dropping forward when pushed in. Quote Link to comment Share on other sites More sharing options...
Madcowz Posted February 22, 2017 Author Share Posted February 22, 2017 Thanks for the replies. Looks like I either need to forget this method of security or purchase and fit another lever. I'll look into how much of a faff this is and how much it will cost me. And Boris, that's a Jetlock. It locks the handbrake preventing use. I know the cable could be cut negating its protection but it's part of a layered approach and is quite visible. Hopefully the wee sh1tes see it and walk on. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 22, 2017 Share Posted February 22, 2017 Hedley, I'd get another transfer lever if it were me. The gearbox lever lock is so easy to use that I just put it on whenever I get out of the 90, in fact I usually do it with one hand as well. Be a shame not to have another layer of high viz security for the sake of an easily replaced lever. HTH Mo 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 23, 2017 Share Posted February 23, 2017 Is it bent for cubby box clearance? Quote Link to comment Share on other sites More sharing options...
Madcowz Posted February 24, 2017 Author Share Posted February 24, 2017 23 hours ago, Bowie69 said: Is it bent for cubby box clearance? Possibly, I might only find out once I've changed it over... On 22/02/2017 at 7:12 PM, Mo Murphy said: Hedley, I'd get another transfer lever if it were me. The gearbox lever lock is so easy to use that I just put it on whenever I get out of the 90, in fact I usually do it with one hand as well. Be a shame not to have another layer of high viz security for the sake of an easily replaced lever. HTH Mo Thanks Mo. You are right. I'm just loathed to work on the car just now as it is so cold out there... But I need to man up and do it. As you say, another layer of hiviz security is worth the effort. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 26, 2017 Share Posted February 26, 2017 I've got a lever and housing here that's a bit rough but you're welcome to it Hedley? Quote Link to comment Share on other sites More sharing options...
Madcowz Posted March 22, 2017 Author Share Posted March 22, 2017 On 26/02/2017 at 2:52 PM, landroversforever said: I've got a lever and housing here that's a bit rough but you're welcome to it Hedley? Hi Ross, Only just spotted your reply, sorry. I'm going to try bending mine back into shape as soon as it stops snowing/raining but if that doesn't work, I may well take you up on your kind offer. Thanks, Heds Quote Link to comment Share on other sites More sharing options...
Madcowz Posted June 6, 2018 Author Share Posted June 6, 2018 Holy thread resurrection... I'm in the process of revisiting this job (and yes I know this was from March 2017. Me bad). I have tried straightening the lever without any luck so will replace. But, FYI, I have seen an angled lever in the parts catalogue and have attached a screenshot of it here. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2018 Share Posted June 6, 2018 Don't rely on the parts book diagrams for accuracy of the actual part design, my transfer lever is straight as I said before. this is a Defender FRC7487 transfer change lever https://www.roversnorth.com/ProductDesc.aspx?code=FRC7487&type=0 defo straight Quote Link to comment Share on other sites More sharing options...
Madcowz Posted June 6, 2018 Author Share Posted June 6, 2018 Cheers Ralph. I managed to get a complete brand new lever housing from Ebay for not far off the price of a lever so I'm happy with that. Looking forward to fitting it and finishing off a job I started over a year ago. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2018 Share Posted June 6, 2018 only a year, took me 8 years to finally wire in my heated front screen 😁 that was a good buy 😎 Quote Link to comment Share on other sites More sharing options...
