Disco-Ron Posted February 26, 2017 Share Posted February 26, 2017 Replaced the lt230 on my 90 14 months ago. .. and today got a horrible grinding noise under power.... diminishes on the over run.... and goes totally with main box is nuetral coasting downhill.... I suspect the idler gear in the tbox has done a bearing..... Any Other ideas?... Not found any unexpected slack in the diffs yet.... got it on 4 axle stands running in gear but as there's no load i can't hear it Quote Link to comment Share on other sites More sharing options...
pat_pending Posted February 27, 2017 Share Posted February 27, 2017 Drain the oil and examine for "party glitter". Also check prop uj's. The only way to properly do this is by dropping the props' and fully articulating the joints. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 27, 2017 Author Share Posted February 27, 2017 I dropped the oil last night..... not examined it yet... Have also removed the bottom plate from the t box... nothing shouting at me yet.... Props off and check the diffs next Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 28, 2017 Share Posted February 28, 2017 Sounds like a failed bearing. Even the prop shaft UJs behave that way when their bearings fail. Are you sure it's from the transfer box? Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 28, 2017 Author Share Posted February 28, 2017 No. I'm not sure..... Will remove props tonight andcheck the diffs as well as i can without removing them..... the props are fine..... I now suspect front diff..... although I'm not sure how that could be heard so much over a noisy v8! Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 28, 2017 Author Share Posted February 28, 2017 So. Its not the transfer box. .... its the front diff... pinion bearings are fubared..... Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 1, 2017 Share Posted March 1, 2017 At least you found it, and replacing a diff is easier and cheaper than the transfer box! Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted March 1, 2017 Author Share Posted March 1, 2017 Generally yes..... however its a forged centre 4 pin.... currently in discussion with mr barker for a special diff that i will never break during my use..... Quote Link to comment Share on other sites More sharing options...
