mad_pete Posted March 18, 2017 Share Posted March 18, 2017 All, Got what looks like Samsonia Perfect No 38 J with 5 1/4 Jaws. The quick release is missing but it turns okay. Took one of the jaws off and it's broken and looks like it has some damage to the screw, Not sure whether to clean and paint it for use or if I'm best of doing something else. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 21, 2017 Share Posted March 21, 2017 Pretty sure I could finish that off for you. Looks pretty similar to my dead one. You're welcome to salvage bits off that for the postage cost. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 21, 2017 Author Share Posted March 21, 2017 Thank you for the offer. I'll measure the screw if it seems similar I would definitely be interested in the parts. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted March 23, 2017 Share Posted March 23, 2017 Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 25, 2017 Author Share Posted March 25, 2017 Mine is 51 cm long but the width looks good. Does length shouldn't matter should it ? Quote Link to comment Share on other sites More sharing options...
mad_pete Posted March 25, 2017 Author Share Posted March 25, 2017 Ok now I have it in more pieces I see size does matter.... Quote Link to comment Share on other sites More sharing options...
Romahomepete Posted April 10, 2017 Share Posted April 10, 2017 My dad used to work for C and J Hampton and Company in Sheffield, the originaal manufacturer of Record vices, at one stage he was in charge of the vice lines. He would never entertain a quick release vice, he thought they were the spawn of the devil as you were always only working with half a nut. Th only thread on a vice screw as far he was concerned was a full acme, you could get plenty of leverage without anything letting go. I do now know how to take a vice to pieces and can even make the tool for tightening jaw plates. Peter Quote Link to comment Share on other sites More sharing options...
seismech Posted May 28, 2019 Share Posted May 28, 2019 Does anyone have this part for a Samsonia perfect vise, type 38A Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 29, 2019 Share Posted May 29, 2019 @CwazyWabbit might know where to get one. Quote Link to comment Share on other sites More sharing options...
Blanco Posted May 29, 2019 Share Posted May 29, 2019 Braze it? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 29, 2019 Share Posted May 29, 2019 Can you make it out of a piece of 8mm plate? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted May 30, 2019 Share Posted May 30, 2019 14 hours ago, landroversforever said: @CwazyWabbit might know where to get one. The last one of those I just brazed back together and it's held fine, they break in that spot when they get bent if the vice is dropped. Well strictly speaking they tend to break when being straightened without heat. Is there nobody near you that can braze it up? Whereabouts in Kent? Quote Link to comment Share on other sites More sharing options...
Romahomepete Posted June 1, 2019 Share Posted June 1, 2019 The screw and half nut on quick release vices is always the weak point and the half nut wears and the spring blade loses its tension. They can be repaired if you know what you are doing but I was trained to keep away from quick release models. Peter Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 3, 2019 Share Posted June 3, 2019 On 6/1/2019 at 7:39 AM, Romahomepete said: The screw and half nut on quick release vices is always the weak point and the half nut wears and the spring blade loses its tension. They can be repaired if you know what you are doing but I was trained to keep away from quick release models. Peter I've over 70 vices (yeah sad I know) with a fair selection of those being quick release, some over 100 years old. Not come across a quick release vice half nut that ever needed more than a good clean to stop it slipping. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 4, 2019 Share Posted June 4, 2019 On 6/3/2019 at 1:39 PM, CwazyWabbit said: I've over 70 vices That is quite some vice you have Barry Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 5, 2019 Share Posted June 5, 2019 15 hours ago, mickeyw said: That is quite some vice you have Barry The biggest one is 😛 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 5, 2019 Share Posted June 5, 2019 2 hours ago, CwazyWabbit said: The biggest one is 😛 Is that the wheelbarrow job one? or have you trumped that one? Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 5, 2019 Share Posted June 5, 2019 2 minutes ago, landroversforever said: Is that the wheelbarrow job one? or have you trumped that one? That's enough trump talk for one week thank you. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 6, 2019 Share Posted June 6, 2019 On 6/5/2019 at 7:54 AM, landroversforever said: Is that the wheelbarrow job one? or have you trumped that one? Yeah, the pic with the Guinness shows it better 3 Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted June 7, 2019 Share Posted June 7, 2019 I would hate to be one of the removal men if you ever moved house! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted June 8, 2019 Share Posted June 8, 2019 On 6/7/2019 at 9:29 AM, daveturnbull said: I would hate to be one of the removal men if you ever moved house! To be fair that is something I'm dreading ...... Quote Link to comment Share on other sites More sharing options...
joiner55 Posted November 14, 2023 Share Posted November 14, 2023 Hi this is a message or question/advice for/from CwazyWabbit. Reading through all these question and answers on hear I think you might be the right person to ask, I'm having a go at resurrecting a No38 model J Samsonia vise. It's not had the roughest of lives so it's sort of worth doing except the QR springs broken, do you know of where I could get another one please ? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 14, 2023 Share Posted November 14, 2023 27 minutes ago, joiner55 said: Hi this is a message or question/advice for/from CwazyWabbit. Reading through all these question and answers on hear I think you might be the right person to ask, I'm having a go at resurrecting a No38 model J Samsonia vise. It's not had the roughest of lives so it's sort of worth doing except the QR springs broken, do you know of where I could get another one please ? How broken? If it's just the end it is usually possible to heat the end of the spring till red and fashion a new end to the spring if you get what I mean. There's a lot more vice nerds over on https://www.mig-welding.co.uk/forum/threads/show-us-your-bench-vice-s.52872/page-434 they might have ideas as to where a replacement can be found. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted November 14, 2023 Share Posted November 14, 2023 Vice Works 2 Quote Link to comment Share on other sites More sharing options...
joiner55 Posted November 21, 2023 Share Posted November 21, 2023 Hi again CwazyWabbit sorry for delay in replying and thank you for your original reply, unfortunately the springs broken in the middle. I did think about having a go at welding it but it seems the springs the week point as it is so welding it might only work for a short term. Also thanks daveturnbull but I've already been intouch with Vice Works and unfortunately they couldn't help. I have however been trawling tinternet and found a Record vice QR spring that I think I might be able to make work. Quote Link to comment Share on other sites More sharing options...
