Landyspud Posted March 19, 2017 Share Posted March 19, 2017 Hi guys been looking at one of these boost pins which fits in the fuel pump and replaces the standard one was wondering if anyone thought they're worth they're money or has fitted one ? Already tuned up the overall fuel delivery and turbo/intake system. Cheers Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 19, 2017 Share Posted March 19, 2017 Junk. 1 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 24, 2017 Share Posted March 24, 2017 You can seriously overfuel a TDI with the standard pump.... Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 26, 2017 Share Posted March 26, 2017 The profile of the pin isn't wildly different from the steepest profile of the standard pin, which has variable profile by being machined eccentrically. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 26, 2017 Share Posted March 26, 2017 The boost pins do have a different profile than the stock pins. They give less off boost fueling with the maximum on boost fueling. This lets you have no smoke with the proper peak boost fueling if you are running high boost levels. The stock pins do not have enough range at high boost to give the right levels both on and off boost. They are not a good choice if you are running 15 psi, but make sense at 25. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 26, 2017 Share Posted March 26, 2017 That's an awful lot of stress for the engine to handle. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 26, 2017 Share Posted March 26, 2017 My reference to being just is also referring to poor quality materials, that wear badly. If you do a search for them you should see a few threads about it. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 26, 2017 Share Posted March 26, 2017 21 minutes ago, Bowie69 said: My reference to being just is also referring to poor quality materials, that wear badly. If you do a search for them you should see a few threads about it. I think there was only a batch from one supplier that had wear problems. You can't make a blanket statement that they are all junk when many different company make them. Quote Link to comment Share on other sites More sharing options...
