Is it necessary?
Is it necessary to drain rear salisbury diff to take any play out of wheel bearings? or will jacking it up from either side be enough to cause the oil to run to the other side?
Modified the axle when i did the disc conversion to remove the outer oil seals so it's lubed from the axle tube.
TIA
Pete
