Les Brock Posted March 27, 2017 Share Posted March 27, 2017 Well here we go .. Fault - Steering jams on full lock Jacked front end up, both wheels of ground, wheels wont turn either way, transfer box in neutral wheels rotate as expected. transfer back into high, passenger side down - wheel locked - would not move either way no matter what gear/transfer box was in Lift other wheel up off ground and on stand turn steering, all moves left-right fine, full lock to full lock Off stands, try and move it, as long as steering moved a little each way fine, go to full lock and it jams solid, ( drivers side wheel seems to lean more than passenger side but that might just be the camber) with a bit of shuffling I can get it straight again. Up on stands once again, strip front end, both CV's seem to be fine, but a bit tight - was there an issue with Ashcroft CV's burring ?????? Going to clean them out and report back Any idea's .....................I'm at a total loss Cheers Chaps Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 27, 2017 Share Posted March 27, 2017 With the drag link disconnected, does the box work OK? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 27, 2017 Author Share Posted March 27, 2017 Yes mate ! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 27, 2017 Share Posted March 27, 2017 Did the CVs sit fully into the stub axle OK? Otherwise could be rubbing against inside of swivel housing on its back edge? Are they the one piece or two piece (separate stub shaft) joints? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 27, 2017 Share Posted March 27, 2017 Have the CVs been pulled in and got the Circlips on them? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 27, 2017 Author Share Posted March 27, 2017 As far as I am aware they were, Ashcroft HD Cv's one piece. one thin shim and circlip holding cv into stub axle. Drove fine on Saturday, just went to get her off the drive at early o'clock Sunday morning to go to Newbury and locked, you can see the scuff marks on road as though front locker was in and not allowing diff to do its job when turning, and steering in unbelieably heavy, when stationary and to suffle to get it to move to get it back on the drive ! Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 27, 2017 Author Share Posted March 27, 2017 Pulled half shafts from CV's one of the "C" clips holding the shaft into the CV was broken ?? The alloy collar has slid up the spline about 20mm on the long shaft, the one with the broken C clip if this has any bearing ?? Quote Link to comment Share on other sites More sharing options...
ballcock Posted March 27, 2017 Share Posted March 27, 2017 Sounds like you diff is jamming, with both wheels off the ground and an open diff the opposite wheel will rotate the other direction. Could your half shaft be going too far in jamming the diff? 1 Quote Link to comment Share on other sites More sharing options...
TSD Posted March 27, 2017 Share Posted March 27, 2017 4 hours ago, Les Brock said: was there an issue with Ashcroft CV's burring ?????? Just in case it's useful... http://www.ashcroft-transmissions.co.uk/images/source/CV_joint_rework.pdf I've got a pair of early Ashcroft HD joints that I keep meaning to rework at some point. They were very tight - difficult to move by hand - but I couldn't spot a problem when they were on the vehicle. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 27, 2017 Share Posted March 27, 2017 2 hours ago, Les Brock said: Pulled half shafts from CV's one of the "C" clips holding the shaft into the CV was broken ?? The alloy collar has slid up the spline about 20mm on the long shaft, the one with the broken C clip if this has any bearing ?? Taking the CV off the halfshaft can break the clip.... I broke a brand new one when I fitted the CV and realised I'd not fitted the spacer.... off came the CV and a broken clip. Cue a wait to pick a new clip the following day. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 27, 2017 Author Share Posted March 27, 2017 1 hour ago, ballcock said: Sounds like you diff is jamming, with both wheels off the ground and an open diff the opposite wheel will rotate the other direction. Could your half shaft be going too far in jamming the diff? Yes, when I had both wheels off the ground, the opposite wheel rotated the opposite way but only with the transfer box in neutral. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 28, 2017 Author Share Posted March 28, 2017 CV's cleaned out, no signs of damage, they are still tight but they aint done much Any ideas of what to try on the transmission side to see if anything jammed ? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 28, 2017 Share Posted March 28, 2017 Have you tried your original tests with the front prop off Les ? Mo Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 28, 2017 Author Share Posted March 28, 2017 Going to try sticking everything in N and seeing the centre diff is stuck in by turning the prop Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted March 28, 2017 Share Posted March 28, 2017 are you sure your front difflock is not engaged? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 28, 2017 Share Posted March 28, 2017 Not a bad shout as Les was working on the air system recently? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted March 28, 2017 Author Share Posted March 28, 2017 Dave, front axle is currently down to just the tube, I pulled the air line off the solenoid to check it was not engaged all seems free. its always possible the rear is stuck in , but would'nt have thought that have an effect on the centre diff/front end Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 1, 2017 Author Share Posted April 1, 2017 Hi all, Finally got a few mins to myself,when it was dry - jacked up rear offside (dont forget only thing left in the front is the diff) zero rotation .................... into Neutral, centre diff unlocked - checked with spanner - still zero rotation, looks like rear diff lock stuck in ! Wibbling at mo trying to get it to unlock ! Quote Link to comment Share on other sites More sharing options...
ballcock Posted April 1, 2017 Share Posted April 1, 2017 5 hours ago, Les Brock said: Hi all, Finally got a few mins to myself,when it was dry - jacked up rear offside (dont forget only thing left in the front is the diff) zero rotation .................... into Neutral, centre diff unlocked - checked with spanner - still zero rotation, looks like rear diff lock stuck in ! Wibbling at mo trying to get it to unlock ! You didn't happen to leave the hand brake on? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 3, 2017 Author Share Posted April 3, 2017 On 01/04/2017 at 10:32 PM, ballcock said: You didn't happen to leave the hand brake on? Nope all off. 1 Quote Link to comment Share on other sites More sharing options...
