Lefstop Posted April 9, 2017 Share Posted April 9, 2017 Hello new guy on the block my rr p38 1997 turbo 4x4 has some door locking problems electronic door opener does work must manually pull up right door locking mechanism to open the back hatch. To lock the car I must push down right door locking button not sure where to start thanks Quote Link to comment Share on other sites More sharing options...
walace58 Posted April 10, 2017 Share Posted April 10, 2017 My 94 rrc had half the problem you have in that on unlocking the button did not come up far enough to release the lock. Oiling of the mechanism was tried, but they are not supposed to be oiled. It would always lock ok . I am told it is a detent spring in the mech that has weakened. Need a new mech to clear the problem. Quote Link to comment Share on other sites More sharing options...
walace58 Posted April 10, 2017 Share Posted April 10, 2017 Rereading you post, it appears you unlocking solenoid is not operating. You need first to access the solenoid and see whether any power is getting to it to see when you activate the unlocking. Then work backwards or forwards from that. Quote Link to comment Share on other sites More sharing options...
