Bruno 300 Posted April 13, 2017 Share Posted April 13, 2017 Having spent more time than I could have done when I was gainfully employed I eventually tracked down the following electrical fault, hopefully by sharing this it may be a time saving tip and therefor helpful to others. Note the black wire which is routed over 'the white plastic Flash/High Beam light switch toggle' - centre of pic. After 21 years the black wire fractured and eventually separated as a result of being flexed whenever toggled. With care the switch can be disassembled and the broken wired could have been repaired but I was so relieved to have discovered the fault I treated my favourite vehicle a new one! Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 16, 2017 Share Posted April 16, 2017 Good to know these things when it happens to you. Nigel Quote Link to comment Share on other sites More sharing options...
