How to fit oilpressure sender & idiot light on 200 / 300 Tdi ?
Arjan
Greetings All !
I was given a Durite oil pressure gauge & sender and want to fit this to the 300 Tdi in the 110.
However - one obviously needs some sort of "splitter" for this, so both the warning light switch and the gauge sender unit get to the (lack of..) oil pressure.
I failed so far to find something to solve this/
What can I use please ?
Thank you very much !
But where to get these parts ?
ETC4033 & ETC4034 seem NLA here...
Ideally, I need to fit a pressure gauge to 3 engines....
Edited by Arjan
In the other thread I linked, it says:
Quote
The tapped hole that the factory low pressure switch fits into is M10*1 and the other larger tapped hole is M16*1.5
So any universal T-piece from ebay would get you there.
Do you know what thread the durite is?
Hi.
I used a flex brakeline from the engine to a t-piece from the rearaxle bolted to the bulkhead. That way I thought I could secure the connections to it better than on the side of the engine. Have worked well for the last 10 years and the threads matched (not that I measured them though, but not leaking or running loose).
/mads
