doddel Posted April 26, 2017 Share Posted April 26, 2017 I need to replace the distributor on my 6 cilinder series 3. I'd like to go for one of these electronic types, but you can find them at like 70 £ all the way up to over 300 £. So, simple question: which one to go for? Any help would be appreciated! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 26, 2017 Share Posted April 26, 2017 I had an Aldon Ignitor on my V8 and that was a decent bit of kit. I'd go for magnetic trigger rather than optical if that's still a choice. Well, I'd remove the dizzy and fit Megajolt if it was my choice I did like the 6cyl, makes a lovely burble. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 26, 2017 Share Posted April 26, 2017 I've found SimonBBC's products very good: http://www.simonbbc.com/land-rover Do you have 25D6 or 45D6 distributor? If it is in good order, you can just fit the pickup and amp, which keeps costs down nicely. http://www.simonbbc.com/tune-up-kits/tune-up-by-vehicle/ultimate-22d6-25d6-tune-up-kit-mg http://www.simonbbc.com/electronic-ignition-kits/land-rover-electronic-ignition-45d6-powerspark-6-cylinder But yes, I would MJ it too Quote Link to comment Share on other sites More sharing options...
doddel Posted April 26, 2017 Author Share Posted April 26, 2017 29 minutes ago, FridgeFreezer said: I had an Aldon Ignitor on my V8 and that was a decent bit of kit. I'd go for magnetic trigger rather than optical if that's still a choice. Well, I'd remove the dizzy and fit Megajolt if it was my choice I did like the 6cyl, makes a lovely burble. looks great, but this really is too complicated (and overkill) for my type of use I am more looking for a straightforward swap Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted April 26, 2017 Share Posted April 26, 2017 Think Luminition used to do one that covered the 4 cylinder and 6 cylinder models if they are still around had one on my then 4 cylinder S3 and it was great but not sure if they are still going or not though Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 26, 2017 Share Posted April 26, 2017 TBH the Maplin amplifier kit takes the load off the points and costs naff all. Quote Link to comment Share on other sites More sharing options...
missingsid Posted April 26, 2017 Share Posted April 26, 2017 5 hours ago, doddel said: looks great, but this really is too complicated (and overkill) for my type of use I am more looking for a straightforward swap True if you do not need waterproof etc. however as my dizzy was warn and therefore the problem it was worth it eitherway. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 26, 2017 Share Posted April 26, 2017 This one: http://www.simonbbc.com/bundle-deals/high-energy-bundles/land-rover-2.6-high-energy-45d6-electronic-distributor-and-coil Quote Link to comment Share on other sites More sharing options...
doddel Posted April 27, 2017 Author Share Posted April 27, 2017 so they have a 'standard electronic' and an 'electronic high energy' version. Both seem to fit the 2.6 engine. Why would I pick the more expensive one? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 27, 2017 Share Posted April 27, 2017 If you were running LPG for example, I would go with the higher energy item. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 27, 2017 Share Posted April 27, 2017 High energy gives a stronger spark and the price is the same.... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 27, 2017 Share Posted April 27, 2017 22 minutes ago, Red90 said: High energy gives a stronger spark and the price is the same.... Only with a higher power coil I'd wager. Std. coils are ~3ohms, last high-power one I had (MSD I think) was ~1 Ohm. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 27, 2017 Share Posted April 27, 2017 (edited) 4 minutes ago, FridgeFreezer said: Only with a higher power coil I'd wager. Std. coils are ~3ohms, last high-power one I had (MSD I think) was ~1 Ohm. I provided the link....which includes the correct coil. Quote Our Signature Electronic 45D6 High Energy distributor and Coil bundle deal Suitable for the 6 cylinder Land Rover Land RoverComes complete and ready to fit with no extra parts needed.Our products have a finish that is second to none with high qualty internal components and comes with a 24 month warranty.Inside the distributor is our electronic module developed and tested by simonbbc.com to replace the troublesome points system with a modern magnetic pick-up therefore we can offer a full 1 year warranty on the module.This system replaces the 22D6 & 25D6 distributors and is matched to an electronic ignition coil (<1.5ohms). Edited April 27, 2017 by Red90 Quote Link to comment Share on other sites More sharing options...
