Weep now a leak?
Hello all, it's been a while but it's time to get the spanner out and fix a bad weep I've developed on my 300 Tdi Defender Lt230. My question is' is it worth trying to fix the leak/ weep on the intermediate shaft ( l'm assuming it's where the leak is coming from) or try getting my hands on a new/ refurbished Lt230 case with the steel sleeve. Would a discovery series 2/2A transfer case fit in a Defender? In all it's got the better ratio for long drives, I believe about 15%. Thanks ted.
Discovery II LT230s usually lack centre diff lock, so that would be a bad source.
Can you not replace the O-ring, perhaps with a slightly thicker one if a new standard one doesn't cure it?
