PVB Posted May 5, 2017 Share Posted May 5, 2017 Is a Discovery 1997 - 300Tdi and I'm having problems finding the right measure for the pieza in bronze. Need help! I bought 52mm and it fall out. Now I'll try 2" we use metrics. Thanks LR mates! Quote Link to comment Share on other sites More sharing options...
Boydie Posted May 6, 2017 Share Posted May 6, 2017 I think from memory that they are 50mm. They also go in the other way around and when you strike the center of the welsh plug it causes it to expand at the outer circumference causing it to seal tight in the cylinder block. Use some sealant on the edges before you insert it though Quote Link to comment Share on other sites More sharing options...
