westsail Posted May 20, 2017 Share Posted May 20, 2017 Hello everybody, I am thinking about buying a series landy. It is a 109 ragtop, 2.25 petrol living in Spain, 4 gear gearbox, no overdrive. Now, according to its (spanish) paperwork it is from 1970 and by its looks it is ex-mod. But the chassis number says something different, does it not?? (attached you see the riveted plate). According to this plate it is a 3/4 tonner; did the mod not use 1 tonners mainly?? Any help from more experienced members would be highly appreciated. I will take more pics later today and check the number on the chassis (if it ever was swapped, it was a loooong time ago as it will need extensive repair). Thanks a lot and best regards, greetings from spain Fabian Quote Link to comment Share on other sites More sharing options...
westsail Posted May 20, 2017 Author Share Posted May 20, 2017 As promise more pictures - outside and enginenumber Quote Link to comment Share on other sites More sharing options...
Daan Posted May 20, 2017 Share Posted May 20, 2017 Hi, this looks like series 3 to me, which was build from 1972. Daan Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted May 20, 2017 Share Posted May 20, 2017 If you want the full detail, down which regiment it served with, and what their favourite pasta was, you should post the pictures of the plates and engine number on the EMLRA forum (Ex-Military Land Rover Association). You can post without being a member, although obviously it helps you if you register. Remember this is Army speak, If they decide to call it a 3/4 tonne vehicle, then that is what it is classed as. Chassis will vary from contract to contract, that is why the Contract and CES numbers are so very useful. Regards. Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted May 20, 2017 Share Posted May 20, 2017 (edited) I think 3/4 ton was the designation of the ordinary LWB. The 1 tonne was a rather different beast with heavy duty suspension, lower ratio steering, wide wheels and an all-helical transfer box giving a maximum sppeed in the low 50's This doesn't mean that yours is the same as a standard civilian one - the suspension and other parts may be special. I'd have put it as very late 70's - early 80's - it has a Vin no - SALL. . . . . - earlier ones didn't. It could be that military vehicles acquired them earlier than civilian ones or something. My 'T' reg S3 didn't have a vin no - just a chassis no - but my X reg LWB did. Edited May 20, 2017 by secondjeremy Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 20, 2017 Share Posted May 20, 2017 The reg number on that plate is military, so it it's definitely ex-mod if there was any doubt. As above, the 3/4 ton was the 109 designation. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted May 20, 2017 Share Posted May 20, 2017 Entering your chassis number here comes back with this Quote Link to comment Share on other sites More sharing options...
westsail Posted May 21, 2017 Author Share Posted May 21, 2017 Thanks a lot guys! In total it really looks like the year in the paperwork is wrong, doesn't it? Also the engine number is from a 8:1 5 bearing mod engine (could have been a motor swap though...) Will keep you updated. ? Quote Link to comment Share on other sites More sharing options...
neil110 Posted June 12, 2017 Share Posted June 12, 2017 Typically military rebuilt engines are painted in a pale turquoise colour. The terracotta red of yours is the colour it would have been painted at the LR factory. The military 109 was designated as a 3/4 ton vehicle but apart from the CL spec vehicles they all had heavy duty suspension Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted June 12, 2017 Share Posted June 12, 2017 (edited) From what my dad used to say was that the army always used to run stuff de-rated so they wouldn't be loaded to the hilt in need of getting out of a situation so although it may carry a ton they would only carry up to 3/4 ton but someone else from an army background may be able to verify. Edited June 12, 2017 by Cornish Rattler Quote Link to comment Share on other sites More sharing options...
western Posted June 15, 2017 Share Posted June 15, 2017 most LR even 110's are rated for a 3/4 ton load carrying ability, the KC part of your military reg puts it around 1985 to 86 when new & into service, or 84 to 85, it almost corresponded to the civilian vehicles registration year letters on reg plates of normal vehicles, Quote Link to comment Share on other sites More sharing options...
