ggeoff Posted May 26, 2017 Share Posted May 26, 2017 Hi I have had trouble with my Disco II 1999 it was overheating. Water pump replaced and also later the radiator. I had to replace 4 hoses. At present the heater works and the car is not overheating and there is no coolant loss but there is the sound of coolant sloshing around the heater. But the coolant pressure is still there 12 hours later. I have tried to bleed all the air out of the coolant system but still have the noise from the heater. The car had its head gasket replaced last year in May. My garage has done a test for exhaust gas in the coolant and that was negative. Apart from the pressure the car is running well. Quote Link to comment Share on other sites More sharing options...
bear Posted May 27, 2017 Share Posted May 27, 2017 Hi, Just checking that when you bled the system did you unclip and raise the coolant resevoir above the bleed screw height? Regards, Griff Quote Link to comment Share on other sites More sharing options...
