steve b Posted July 11, 2019 Share Posted July 11, 2019 Yep , that's what you need to connect the return pipe to the stub , you will also need the same spec in 10mm to extend/connect the feed pipe cheers Steve b Quote Link to comment Share on other sites More sharing options...
Wheely Posted July 12, 2019 Author Share Posted July 12, 2019 thanks @steve b -since I am changing the whole hose, so to be on the safe side, the 8mm would be suitable for both legs (one going from #5 to engine and one from engine to #3), right? or one needs to be a 10mm? Quote Link to comment Share on other sites More sharing options...
steve b Posted July 12, 2019 Share Posted July 12, 2019 factory feed pipe is 10mm outside diameter so probably 8mm bore or so , personally I would go with the size that is a good fit onto the tank and engine end pipe stubs , if it's loose it will be harder to get a good leak free connection cheers Steve b Quote Link to comment Share on other sites More sharing options...
