oz4aex Posted June 1, 2017 Share Posted June 1, 2017 Land rover lightweight temperature meter It is a 24v -http://www.armyvehicles.dk/lr88half.htm I have problems with temperature meter oil and water They'll get to the top right away when I turn on the ignition how can that be ? Are there sensors! Or is it anything else? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 1, 2017 Share Posted June 1, 2017 Been through the mill on this one.... I found some were wired up wrong, one was a 12v gauge, but even with a 24v gauge, it was wrong. In the end, I pulled the needle off the gauge, and pushed it back on in the right place Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 3, 2017 Share Posted June 3, 2017 It could be that the wires to the sender units are shorting out on the engine or bulkhead. It is also possible that the senders are mismatched to the gauges, or that the gauges have been damaged by incorrect voltage being applied (eg. welding without the wiring being disconnected from the battery and generator). Quote Link to comment Share on other sites More sharing options...
neil110 Posted June 5, 2017 Share Posted June 5, 2017 Are they electric gauges or capillary? Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 6, 2017 Share Posted June 6, 2017 I had issues with the oil temperature gauge on a 24v Lightweight. If I recall correctly, the senders are the same as on the 12v models, and the gauges are different (look the same from the front, but electrically different and don't use a voltage stabiliser like the 12v gauges). It could be that someone has fitted 12v gauges to your dash. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 6, 2017 Share Posted June 6, 2017 Yup snagger is right, the 24V gauges have a shunt resistor soldered onto the back of them, and have different part numbers compared to the 12V versions. The sender's are the same as on 12V vehicles. Quote Link to comment Share on other sites More sharing options...
neil110 Posted June 6, 2017 Share Posted June 6, 2017 Not sure if it will be the same on a series vehicle as my 110 but I had some problems getting sensible readings from the engine temperature gauge. It would go to the top of the red section within a couple of minutes of starting the engine. The "fix" was to earth the metal case of the gauge. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 6, 2017 Share Posted June 6, 2017 The earth for gauges is normally under one of the knurled nuts that hold the gauge in place, so that shouldn't be an issue, so yes you are right, it does need earthing, or the shunt won't work! Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 6, 2017 Share Posted June 6, 2017 That earthing issue is a very good point, and is easily spotted by the readings increasing when the dash lights are turned on. I had that on my 109. Well remembered, Neil. Quote Link to comment Share on other sites More sharing options...
neil110 Posted June 8, 2017 Share Posted June 8, 2017 Thanks. To be honest it was not the case that the earth was missing, neither had it become detached, it was simply that the knurled nut had worked loose. I was worried because the ambient temperatures were over 37 Deg C and I thought I had a cooling problem Quote Link to comment Share on other sites More sharing options...
