Les Brock Posted June 1, 2017 Share Posted June 1, 2017 Hi Chaps, Been having a few vibrations ever since it want back on the road, so time to try and sort it out, It's through the tranmission mainly on acceleration between 35-60, removed the rear prop and its very slightly out of alignment by about 5-10 degrees where they are supposed to be in-line, no matter how how move it around it won't line up. surprised I missed it when putting it together TBH So could this be the cause or be at least adding to it anyway ? and as the prop was bought 2nd hand could it be a front which is supposed to be mis aligned albeit by much more sold as a rear/ or a mis-matched - cobbled one one ? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted June 1, 2017 Share Posted June 1, 2017 rear prop flanges should be inline & front should be out of line, page from the workshop manual in here it also says front prop is shorter than rear [doesn't state if it's applicable to 90 &/or 110] Quote Link to comment Share on other sites More sharing options...
Les Brock Posted June 1, 2017 Author Share Posted June 1, 2017 Cheers Western, Thing it they will not go in-line ?, they are always out of phase I can get it close, but go another spline and its way out, go 180 and its the same Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 1, 2017 Share Posted June 1, 2017 90 degrees? Quote Link to comment Share on other sites More sharing options...
western Posted June 1, 2017 Share Posted June 1, 2017 possibly it's mismatched parts or a front prop then. but thought it was possible to get a front prop flanges to line up as well. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted June 1, 2017 Author Share Posted June 1, 2017 7 minutes ago, Red90 said: 90 degrees? But would'nt that then be miss alligned ? I'll try and get a picture Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 1, 2017 Share Posted June 1, 2017 No 90 degrees is still aligned. It does not matter which legs are aligned with the others. Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 2, 2017 Share Posted June 2, 2017 hmmm people seem to have missed the part where he's said "2nd hand" unfortunately that's where I see the problem at... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 2, 2017 Share Posted June 2, 2017 Yeah... could be made by Britpart... or even have a twist in it? 5 degrees is possible I would think. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 2, 2017 Share Posted June 2, 2017 I think you need to buy another prop. As far as I can tell 200tdi and earlier 90s have the same length prop front and rear though the front is misaligned. From memory the front prop can be aligned so I would suggest yours is twisted/badly made. Red90 I was under the impression that 90° was still out of line and therefore create a vibration. Mike Quote Link to comment Share on other sites More sharing options...
Les Brock Posted June 2, 2017 Author Share Posted June 2, 2017 Thanks for the replies, bit the bullet and ordered one from Gwyn Lewis, cant be having with faffing about, hopefully it'll cure it, knowing my luck however it prob wont make any difference 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 3, 2017 Share Posted June 3, 2017 Just to confirm my understanding, Les, it's the yolks that are slightly misaligned due tot he slip joint splines, not the diff and transfer box flanges out of parallel? If the former, then as others surmised, I suspect a twisted shaft or one made from two damaged shafts, and a new standard replacement will do the job. If the latter, then I'd recommend speaking to Bailey Morris, who'd make a specifically phased shaft for your specific dimensions - suspension lifts and transmission/engine relocation commonly cause these issues and they're used to dealing with it. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted June 5, 2017 Author Share Posted June 5, 2017 On 03/06/2017 at 2:37 PM, Snagger said: Just to confirm my understanding, Les, it's the yolks that are slightly misaligned due tot he slip joint splines, not the diff and transfer box flanges out of parallel? If the former, then as others surmised, I suspect a twisted shaft or one made from two damaged shafts, and a new standard replacement will do the job. If the latter, then I'd recommend speaking to Bailey Morris, who'd make a specifically phased shaft for your specific dimensions - suspension lifts and transmission/engine relocation commonly cause these issues and they're used to dealing with it. Yes - its the yokes that will not align by roughly 5 degrees, the nose of the diff does angle very slightly upwards due to the King set up, but no more that the tray back used to and that was fine with a normal rear prop in, looks like I picked up a old dog one TBH, the one from Gwyn was ordered late Friday and it arrived by 11am this morning cant ask for better than that 2 Quote Link to comment Share on other sites More sharing options...
