tbeagley Posted June 10, 2017 Share Posted June 10, 2017 Hi all! What's everyone's opinion on fitting wheel spacers. Should I, shouldn't I? Safe or not? Cheers! Quote Link to comment Share on other sites More sharing options...
ballcock Posted June 10, 2017 Share Posted June 10, 2017 I have run a Discovery in the past with no issues, although I do prefer the Bulldog type spacers which have the concentric lip. Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 10, 2017 Share Posted June 10, 2017 They increase loadings on wheel bearings and steering components, so can lead to faster wear, but regular maintenance should detect this. The biggest issue is that any difference in the individual brake performance, tyre pattern, tyre pressure or surface grip will produce an amount of pull now that the tyre contact patch is not aligned with the swivel pins, as will hitting potholes or other uneven surfaces. It shouldn't be a problem, but is worth knowing. It's no different with heavily offset wheels. Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted June 10, 2017 Share Posted June 10, 2017 I cant say Ive seen any deterioration in either handling or wear, and ive got them on 2 vehicles - Previously I was using Forward Control rims which exhibit the same effect. In 10 years of driving my V8 Stage 1 S111 - as a daily driver (and for work) I didnt have to replace the wheel bearings (running Forward Control Rims NB Not 1 ton rims) Quote Link to comment Share on other sites More sharing options...
Arjan Posted June 10, 2017 Share Posted June 10, 2017 We have 3 LR's and all 3 have 30 mm spacers for 10 years + from Kenson in Wednesbury. No problems. Make sure you get the best quality you can afford. Or don't get them at all. Quote Link to comment Share on other sites More sharing options...
gerrymc123 Posted June 11, 2017 Share Posted June 11, 2017 Do they actually serve a purpose? Quote Link to comment Share on other sites More sharing options...
tbeagley Posted June 11, 2017 Author Share Posted June 11, 2017 Thanks for the replies. Is there a best one to go for? Are Terrafifma ones OK? Cheers! Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted June 11, 2017 Share Posted June 11, 2017 9 hours ago, gerrymc123 said: Do they actually serve a purpose? Such a good question - if you want to fit a larger tyre than 750-16 or 235 85 R16 then to retain your lock to lock turning circle - you need to move the center-line of the wheel rim outboard (the off-set) to allow a full range of movement. (You can achieve the same with non standard wheel rims that have a bigger off-set - this links with the Forward Control thread that is running along side this) There are others who claim that the wider 'stance' that comes from the increased track-width, makes the vehicle more 'planted' and adds to stability / improves handling - Rather than say Bollox - I've never noticed this - Id leave this to the 'Drifters' and power-sliders to explain how 30mm of additional off-set becomes significant. Lastly - there are all those (probably the majority) who just love that way spacers make their pride and joy look - and who are we to judge - Quote Link to comment Share on other sites More sharing options...
