Jocklandjohn Posted June 12, 2017 Share Posted June 12, 2017 My bulkhead is corroding below the windscreen section, the bit where the air vents are, mostly along the thin strip above the vents where the wipers and water jet emerge. I'm intending repairing it by removing the section down to the bonnet hinges - ie removing the vents completely and replacing with a piece of steel bent to a right angle at top - to go under windscreen frame to replicate the original section. The two sides where the mock hingey things are at each edge of the windscreen are solid as is the rest of the bulkhead below (except for footwells - another job). Aside from wiper gear and water jet piping in at the back of the dash and any wiring, are there any other things that I need be aware of ? Quote Link to comment Share on other sites More sharing options...
