neil110 Posted June 22, 2017 Share Posted June 22, 2017 (edited) Right, from the top. Carling hazard switch fitted, indicators work, hazards don't. 12v at green when ignition is on, 12v at purple when ignition is switched on or off When switching hazards on, indicators stop working. Removed the green and the light green wires from the switch, indicators don't work at all. Removing any or all of the other wires has no effect at all on the indiocators Connected green to light green through a fuse and not via the switch. Indicators work and hazards work, but hazards only work when the ignition is switched on. Connected light green pin to the fuse holder where the green and light green are connected, hazards work with the ignition off, but the oil pressure, hand brake warning and charging light come on as well Any thoughts chaps, please? MoT on Tuesday and this is the first time I have tried using the hazards since the test last year Edited June 22, 2017 by neil110 additional info Quote Link to comment Share on other sites More sharing options...
western Posted June 22, 2017 Share Posted June 22, 2017 Start fault finding with this thread https://forums.lr4x4.com/topic/25376-hazard-switch-indicators-fault-diagnosis/ but I suspect a dirty switch as the first thing to look at, as it's had almost no use for 12 months. Quote Link to comment Share on other sites More sharing options...
neil110 Posted June 23, 2017 Author Share Posted June 23, 2017 Thank you for the suggestion Ralph. Turned out to be the flasher unit. Removed it, accidentally dropped it, refitted it and all was restored 1 Quote Link to comment Share on other sites More sharing options...
western Posted June 23, 2017 Share Posted June 23, 2017 accidentally on purpose glad it was a cheap fix. Quote Link to comment Share on other sites More sharing options...
