ianmayco68 Posted June 23, 2017 Share Posted June 23, 2017 Hi all, I've got a 200tdi , is it normal to find oil in the pipe that goes from the turbo to the intercooler ? There's wasn't loads but it was quite wet have I stumbled on the start of a problem ? cheers Ian Quote Link to comment Share on other sites More sharing options...
western Posted June 23, 2017 Share Posted June 23, 2017 Normal, its from the crankcase breather which feeds into the air filter casing. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted June 23, 2017 Author Share Posted June 23, 2017 Cheers western . Quote Link to comment Share on other sites More sharing options...
Boydie Posted June 24, 2017 Share Posted June 24, 2017 Buy and install a decent after market oil catch can and most of the problem is solved, Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted June 25, 2017 Author Share Posted June 25, 2017 I've got an alisport one fitted , have put it all back together and will keep an eye on it . Thought I'd better ask , I knew oil from the catchment tank sometimes got into the pipes, and there was a tiny bit in the pipe from the catchment tank but not even a sign that oil had been in the air box to turbo pipe then the turbo to intercooler pipe was quite wet which had me thinking that the seals in the turbo could be on the way out, the engine stood for over 2 years while I rebuilt her. cheers Ian Quote Link to comment Share on other sites More sharing options...
