reb78 Posted June 25, 2017 Share Posted June 25, 2017 I have three old hubs in the garage from our Discovery 2. Can they be rebuilt? Has anyone done it? Seems a shame to chuck them away. Quote Link to comment Share on other sites More sharing options...
elbekko Posted June 26, 2017 Share Posted June 26, 2017 I've done it on a P38, can't imagine the D2 hubs are all that different. Big circlip holding the bearing in, press out the bearing, look up which one it is, replace, done. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 26, 2017 Author Share Posted June 26, 2017 Are they like these? https://www.lrdirect.com/TAY100060-Hub-Assy-With-Sensor-Ds-Td5-Fro/ Quote Link to comment Share on other sites More sharing options...
elbekko Posted June 27, 2017 Share Posted June 27, 2017 Yes, very similar. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted June 27, 2017 Share Posted June 27, 2017 They look similar from distance but the construction is different, the P38 one is designed to be repaired that's why repair kits are available, you'll not find a circlip on the D2 hub cos it's all encapsulated... better forget about that cos even if you can force out the bearing IMO you'll not be able to fit a new one as to restore the hub to it's initial status also the reluctor ring is very close to the bearing not like in the P38 hub... the D2's ABS system is more sensitive that's why it reacts to wear in the hub even before being a noticeable play in the wheel 1 Quote Link to comment Share on other sites More sharing options...
