Jocklandjohn Posted July 3, 2017 Share Posted July 3, 2017 Got a T-Max compressor - been fine for several years now, not had a huge amount of use to be honest (I'm not running massive tyres and deflating/inflating, simply maintaining main tyres & spare pressures) and has worked without any problems. However today I tried to pump the spare and compressor would not start. Checked the fuse and it's not just blown, it's melted the plastic of the fuse, and slightly melted the fuse-holder. Fuse is 30A and is the one supplied with it. I swapped it out and tried again, same thing after 1 minute of running. Checked all the wiring, battery etc and tried again, blew it immediately the compressor was switched on. Any suggestions where I start looking for the problem? I'm assuming I may have to delve into the compressor internals? The fuseholder's internal wires appear all ok, no stray wires touching etc. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 3, 2017 Share Posted July 3, 2017 I'd check the wires in the fuse holder etc. - there's a fair bit of current flowing, only needs a poor connection to get really hot really quickly, as you're seeing. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted July 3, 2017 Author Share Posted July 3, 2017 1 hour ago, FridgeFreezer said: I'd check the wires in the fuse holder etc. - there's a fair bit of current flowing, only needs a poor connection to get really hot really quickly, as you're seeing. I'd a look earlier and it seemed ok, but I think I might re-solder the connections and see if it helps. Damage looked very localised so you might be right. Thanks! Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted July 3, 2017 Author Share Posted July 3, 2017 3 hours ago, FridgeFreezer said: I'd check the wires in the fuse holder etc. - there's a fair bit of current flowing, only needs a poor connection to get really hot really quickly, as you're seeing. Reporting back to aid anyone else similarly afflicted....cut out a few inches of wire around the in-line fuse holder, inserted a new fuse holder. Switched on and it's humming beautifully and shoving air up the pipe like a good un! Thanks Fridge! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 4, 2017 Share Posted July 4, 2017 Result! Quote Link to comment Share on other sites More sharing options...
