paullee Posted July 11, 2017 Share Posted July 11, 2017 hi chaps at the mo my defender 90 1992 is of the rd with no mot or tax.i got lazy and let it sit for 10 weeks without starting it but it fired up no prob,my question is this i checked the oil and it was well up on the dip stick at least 6inches( oow er mrs) so i thought maybe it was me,so i gave the old girl an oil change and took her around the block as i did change the water pump to,iv been out to start her up this week and the dip stick is well up again about the same as before,could it be diesel getting in or maybe my oil pump? can anyone shed some light? cheers guys Quote Link to comment Share on other sites More sharing options...
western Posted July 11, 2017 Share Posted July 11, 2017 I'm assuming the engine is a 200Tdi ? can you move the dipstick tube up & down ? if so you need to remove it from engine, then at the lower end make sure the ring around the tube is in the correct place & the flared end is made a bit wider, that should make the securing nut grip it better. there was a tech bulletin issued years ago for this problem, if you search the tech archive or this forum it should appear for you to read. search for '200tdi dipstick tech bulletin' or similar. Quote Link to comment Share on other sites More sharing options...
paullee Posted July 11, 2017 Author Share Posted July 11, 2017 4 hours ago, western said: I'm assuming the engine is a 200Tdi ? can you move the dipstick tube up & down ? if so you need to remove it from engine, then at the lower end make sure the ring around the tube is in the correct place & the flared end is made a bit wider, that should make the securing nut grip it better. there was a tech bulletin issued years ago for this problem, if you search the tech archive or this forum it should appear for you to read. search for '200tdi dipstick tech bulletin' or similar. thanks western ill have a look tomorrow hopefuly it is just sliped to fare in Quote Link to comment Share on other sites More sharing options...
paullee Posted July 11, 2017 Author Share Posted July 11, 2017 western just been out in the rain to check lol, you was right the tube is very loose ill sort that out at the weekend many thanks bruv Quote Link to comment Share on other sites More sharing options...
western Posted July 11, 2017 Share Posted July 11, 2017 Your welcome. I used my long needle nose pliers to reflare the inside of the tube, Think I need to do mine again as I can turn the tube, but no up/down. Quote Link to comment Share on other sites More sharing options...
