Andrew N Posted July 31, 2017 Share Posted July 31, 2017 Taken the front propshaft off my 300tdi Defender to replace a UJ, but I can't identify the spider I've taken off. From what I've read it should be 75mm, 83mm or 95mm across - mine seems to be about 91mm. Any ideas what it is and where I might find a replacement? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 31, 2017 Share Posted July 31, 2017 It is not a stock u-joint so you would need to measure up everything carefully and figure out the size or take it to a shop that does driveline work to figure it out. You need the cap diameter and the cap width as precisely as possible. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted August 1, 2017 Share Posted August 1, 2017 Have a look here and see if it helps.... http://www2.dana.com/Expert/wc.dll?hvtss~dedsec~2~13~06~ Quote Link to comment Share on other sites More sharing options...
Andrew N Posted August 1, 2017 Author Share Posted August 1, 2017 Problem solved. It seems I have a wide-angle front propshaft (TVB100610G) which uses the "95mm" UJ spiders (STC4807), which are in fact not 95mm at all but 92mm. Allow for a bit of wear and tear and that matches the one I took out. 1 Quote Link to comment Share on other sites More sharing options...
