sighnbox Posted July 31, 2017 Share Posted July 31, 2017 (edited) Don't see me for ages then 3 times in one week anyway...... 1990 110 was TD fitted with defender 200tdi now/since I had her 15 odd LONG years Changing my TD exhaust for a 200tdi one to go with the engine Got some nice galvanized 200tdi hangers Straight through mid pipe (Terrafirma) Front down pipe and tail pipe from Paddocks and has GT Exhausts written on them Now the front end clamps are the same size holes line up between the Terrafirma mid pipe and the front GT down pipe The back clamps DO NOT..... The back end clamp on the Terrafirma straight pipe is the same as the Terrafirma and GT front clamps as in size and hole positions But the clamp on the tail pipe (Gt prt) as way smaller clamp and the holes are way way off meaning using really skinny bolts and not sure that will be able to pull it together properly or Ive the wrong back/tail pipe any one else had this ??? Spacings on first three clamp holes from centre to centre is 100mm The back/tail pipe clamp hole spacing is 85mm Edited July 31, 2017 by sighnbox Quote Link to comment Share on other sites More sharing options...
dag019 Posted August 1, 2017 Share Posted August 1, 2017 I had a similar problem with a britpart exhaust section using the triangular clamps. I just carefully elongated the holes of both of them until they nearly lined up. But as that was a very cheap part, I expected to have to do some fettling. Quote Link to comment Share on other sites More sharing options...
sighnbox Posted August 1, 2017 Author Share Posted August 1, 2017 SOLVED I was sent a 130 tail pipe for a 300tdi LOL (NO label to check part number)....... new CORRECT one on the way next day delivery At least its just a wrong part and not a Britpart bad fitment prob lol Quote Link to comment Share on other sites More sharing options...
