Arjan Posted August 9, 2017 Share Posted August 9, 2017 (edited) As you guys are a great source of wisdom, etc... I hope you can tell me what this is ? I was led to believe it is a thermosstat housing for the R380 and attaches the oil cooler to ? And the "sensor" ? Warning light or gauge sensor... Thanks Edited August 9, 2017 by Arjan Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2017 Share Posted August 9, 2017 connect to earth & red gear warning light on dash warning light panel, Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 9, 2017 Author Share Posted August 9, 2017 Merci. So this is a R380 oil cooler thermostat thingie ? Quote Link to comment Share on other sites More sharing options...
neil110 Posted August 9, 2017 Share Posted August 9, 2017 (edited) No it is not an oil cooler thermostat, it is an over temperature warning sender unit. The oil cooler thermostat look like this. Although this link says it is for the LT77 it is very similar to the unit I have fitted to my R380 http://www.brit-car.co.uk/search.php?query=ftc1404&xBrand=&part_type=&xSupplierID=&product-sort=&xPerPage=10 R380 type, no illustration, sadly. Price is pretty sad as well. http://www.brit-car.co.uk/search.php?query=ftc2687&xBrand=&part_type=&xSupplierID=&product-sort=&xPerPage=10 Edited August 9, 2017 by neil110 Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2017 Share Posted August 9, 2017 Yes main gearbox Overtemp switch, got one on my R380 but it has a blanking cap not the switch. [ringed in orange on my pic below] I have the switch but haven't yet bothered to fit/wire the switch. some have the unit as noted above & connected to a oil cooler below normal radiator. uses a slate grey/red trace wire from switch to dash light. Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 9, 2017 Author Share Posted August 9, 2017 Thank You !! I have IR guns to measure the various temps... Wonder if the oil cooler is a good idea... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 9, 2017 Share Posted August 9, 2017 Fridge's sticky temp stickers would be able to tell you that, but according to him, 80MPH on French Autoroutes in the ambulance said 'Oui'. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 9, 2017 Share Posted August 9, 2017 15 minutes ago, Bowie69 said: Fridge's sticky temp stickers would be able to tell you that, but according to him, 80MPH on French Autoroutes in the ambulance said 'Oui'. I'll dig the piccy out with the actual number on it but yeah, spent about ~6 hours at 130kph in the French sunshine, ambulance is 2.8 ton and less aerodynamic than skip full of Ikea wardrobes, R380 didn't break a sweat. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 9, 2017 Share Posted August 9, 2017 I seem to remember @Arjan tows a fair bit, suspect temps could be a bit higher then... but as they say, test don't guess, otherwise you can just be throwing good money down the drain. Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 9, 2017 Author Share Posted August 9, 2017 (edited) Me towing often.... We seem to be towing quite a lot but the gearbox seems happy in the Summer around 87 C. Edited August 9, 2017 by Arjan 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 9, 2017 Share Posted August 9, 2017 Arjan - nerr! Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 9, 2017 Author Share Posted August 9, 2017 (edited) Ooh...... Poor Ninety..... Don't we love towing.... Edited August 9, 2017 by Arjan Quote Link to comment Share on other sites More sharing options...
AV8R Posted August 9, 2017 Share Posted August 9, 2017 (edited) 4 hours ago, neil110 said: The oil cooler thermostat look like this. Although this link says it is for the LT77 it is very similar to the unit I have fitted to my R380 http://www.brit-car.co.uk/search.php?query=ftc1404&xBrand=&part_type=&xSupplierID=&product-sort=&xPerPage=10 Interesting. I never knew you could fit an oil cooler to the LT77. Anybody has one ??? Edited August 9, 2017 by AV8R Quote Link to comment Share on other sites More sharing options...
