CJ1 Posted August 10, 2017 Share Posted August 10, 2017 Hi, I am hopefully buying a 3dr Freelander 1.8 petrol. I know what a lot of people say, but this will be my 4th. Loved them all including my Range Rovers and Discovery's. Anyway, it is petrol, really low mileage, less than a year ago it has had the uprated head gasket and uprated parts fitted professionally, it is now idling lumpy which can according to the seller be felt at low speeds. No oil or coolant loss, no blue smoke. The coil packs have been replaced, new spark plugs fitted. What else could it be please? I am taking a bit of a chance on this one, hoping it isn't going to be a swing and a miss lol Cheers. (2001 X Reg) Quote Link to comment Share on other sites More sharing options...
PatM Posted August 10, 2017 Share Posted August 10, 2017 Is it oscillating? Doe the revs go up slight lightly and back down on tick-over? When my MGTF did this (same engine- K-series) it was the pre-cat lamda sensor. Also, an air leak after the throttle-body can cause the ECU to attempt to adjust a lean mixture. The MGTF Crew have loads on K-series engine- google MG FORUMS and go to MG-TF and start browsing. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 10, 2017 Share Posted August 10, 2017 Also HT leads, at this age anything can happen. Quote Link to comment Share on other sites More sharing options...
CJ1 Posted August 18, 2017 Author Share Posted August 18, 2017 I bought the car. The misfire really is minute. I plugged diagnostics in, it came up with misfire due to low fuel, (Needle was very low!) And misfire on cylinder 2 detected. Spark plugs, ht leads, coil packs replaced, and removed and made no difference. Quote Link to comment Share on other sites More sharing options...
PatM Posted August 28, 2017 Share Posted August 28, 2017 Misfire on one cylinder is usually lead/plug/pack. Try swapping it and see if the misfire re-occurs on the other bank? Quote Link to comment Share on other sites More sharing options...
