ThreeSheds Posted August 16, 2017 Share Posted August 16, 2017 I have a Disco 2 and am thinking of getting a set of rock/tree sliders and welding them on (puddle weld in the holes and seam weld the edges where possible/easy).. Are there any downsides with this approach? Cheers Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted August 16, 2017 Share Posted August 16, 2017 Makes them harder to change if you damage them I guess. I welded plates onto the chassis to spread the load then bolted the rock sliders to the plates. If you cut the ends of the plate at an angle you can spread the load a bit when you weld it. 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 18, 2017 Share Posted August 18, 2017 Do disco 2 sliders normally bolt to the body not the chassis (like disco 1 sliders do) if so I can see why you want to weld them. As al say replacement and or sorting rust could be a problem in the future. Mike Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted August 18, 2017 Author Share Posted August 18, 2017 14 hours ago, miketomcat said: Do disco 2 sliders normally bolt to the body not the chassis (like disco 1 sliders do) if so I can see why you want to weld them. As al say replacement and or sorting rust could be a problem in the future. Mike The sliders that I have seen for the D2 bolt on to the sills - so yes, the body. and as for rust, if i clear it all up now, it will probably see me out before it needs doing again Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 18, 2017 Share Posted August 18, 2017 I probably wouldn't weld them to the chassis but I don't see any reason there would be a problem welding them to the body. Mike Quote Link to comment Share on other sites More sharing options...
