D2, 2002 facelift version, headlamp unit, electrical connection
boaterboy
The multi-pin socket at the back of my vehicle's headlamp unit is mounted in a 'plug' type component which can be loosened by turning it through about 30 degrees.
However, the 'plug' cannot then be removed, it seems only possible to push it inwards into the main body of the headlamp unit.
What is the purpose of this 'plug', please?
I discovered it whilst trying to get to the source of a 'clicking' sound in the off-side headlamp which appears to relate to a failed headlamp adjustment device.
Any help relating to this problem would be very much appreciated.
That plug is made as to let you turn and release it inside in case you want to remove the headlamp's rear cover for some purpose and not cut the wiring if you see what i mean... maybe at some point LR wanted to sell the adjustment motors separately but then they chganged theyr mind
Edited by sierrafery
