Nigel feckey Posted August 29, 2017 Share Posted August 29, 2017 On a normal road if I go over a bump traction control kicks in vehicle is pulled violently to left or the right rarely in straight line have to take foot off accelerator immeadiately make sure holding steering wheel firmly just had 4 genuine new hub assemblies fitted along with top and bottom balll joint but the guys at the landrover garage are at a miss as to what could be causing this can anyone point me in right direction Quote Link to comment Share on other sites More sharing options...
dave88sw Posted August 30, 2017 Share Posted August 30, 2017 It's almost certainly something to do with the wheel sensors. It's very easy to end up with too large an air gap on disco 2's as there's an o ring that seals the sensor in and without a light tap on the top of the sensor when fitting, they don't seat properly. The only way you'll know is to get it plugged into diagnostics, they're quite good at recording faults and usually will tell you if the air gap is too large. Alternatively, they don't like having mis-matched brands of sensor, particularly across the same axle, although you say it's had 4 new wheel bearing assemblies, they normally come with the sensors already in them so they should be the same. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted August 30, 2017 Share Posted August 30, 2017 This symptom is caused by a missballance between the wheel speed sensor inputs, i've seen it many times but in most cases was caused by aftermarket hubs, you say your's are genuine, dont misunderstand me but did you buy them yourself and you van confirm they are with Timken bearings and Wabco sensor?... also are your tyres all the same brand, standard dimension and even pressure per axle? Quote Link to comment Share on other sites More sharing options...
Nigel feckey Posted August 30, 2017 Author Share Posted August 30, 2017 Fitted by landrover servicesNottingham it has new mud terrain tyres Quote Link to comment Share on other sites More sharing options...
sierrafery Posted August 30, 2017 Share Posted August 30, 2017 What dimension tyres and what pressure? Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted August 30, 2017 Share Posted August 30, 2017 If that car came into my workshop the first thing I would do is to scope all 4 wheels together.In my experience your symptoms are as a result of cheap aftermarket hubs with the wrong number of reluctor teeth, or a failing SLABS ecu. Either are very possible.As long as all 4 tyres are the same size it shouldn't cause an issue. Having incorrect tooth counts with aftermarket hubs causes some really weird issues as the poor SLABS ecu gets totally confused. Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 1, 2017 Share Posted September 1, 2017 On 30/08/2017 at 11:39 AM, Nigel feckey said: Fitted by landrover servicesNottingham it has new mud terrain tyres That doesn't mean they used genuine or pattern parts, but I'd guess at Britpart and that could be the problem. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 1, 2017 Share Posted September 1, 2017 I have two Bearmach hubs on my D2 - on on the front, another on the back with the original parts on the other side. They dont seem to have caused any issues, so if people are looking for an aftermarket option, these seem to be ok Quote Link to comment Share on other sites More sharing options...
