If you value this forum's future please support us
Gazzar
Bleeding brakes, ezibleed replacement
Gazzar    31
Good afternoon,
My front brake pipes need replacing, and my ezibleed is nearly dead, due to neglect.
What is the current best tool for bleeding brakes? My 109 has a pdwa and so is a bit of a challenge to bleed at times.
G.
Share this post
Link to post
Snagger    197
A vacuum bleeder would be the very best option if you can find one as it'll remove the air from the various traps.  I suspect they're more expensive, but used in conjunction with the Ezibleed reservoir and cap, with a restrictor on the inlet to the reservoir so that the vacuum can develop in the brake system and allow the air to expand and force its way ot.
Share this post
Link to post
Bowie69    382
Honestly, the Eezibleed, or similar contraptions are very good value for money....
Share this post
Link to post
Snagger    197
They are, but they have severe limitations on 109s with twin leading shoe systems (which also have the PDWA valve).  They work extremely well on models without those, though.
Share this post
Link to post
zardos    6
My brother had something similar to this which worked very well, you did not need to keep topping up the reservoir and thus you did not run the risk of running out and pulling more air in to the system. It provides pressure similar to manual brake pumping.
The only downside is the cost.
Share this post
Link to post
Gazzar    31
Yes, the PDWA is a challenge.
I'm going to try one of the Sealey  vacuum kits for about £40 on ebay.  I'll report back.  I might do the photo montage thing I used do back in the day...
Thanks,
G.
Share this post
Link to post
Snagger    197
I think replacing the PDWA valve with a level sensitive cap from a RRC/Disco/Defender is going to give earlier and more reliable warning than the valve, and would allow the valve to be deleted.  The trouble is that it wouldn't warn of a failed master cylinder seal in one circuit.
Share this post
Link to post
Gazzar    31
Happy enough with the valve, never caused me problems, and rebuilds look simple enough, so no real reason to delete. I might add a level cap at some stage, though.
G.
Share this post
Link to post
reb78    140
Ive got a pdwa valve on the 110 and have never had an issue bleeding with an eezibleed. When my eezibleed broke, i bought another because i rate it.
Share this post
Link to post
Gazzar    31
Bit of an update.  I used the Sealey Vacuum bleed device to drain the system today, it's easier to use than the ezibleed, and is better built, I think.   The Gunson stuff always leaves me feeling that if they'd spent an extra couple of quid, then they'd have a much better product, it's good, but the Sealey is better.
I did have a bit of a struggle to get the bleed cap over the nipple, but that can be fixed with a bit of silicone grease, a good complaint, if you will.
What was interesting, was that half way through the drain process, the fluid had a load of air bubbles for a bit, then the fluid reverted to pure fluid until it ran dry.  I wonder if they were in the system all along, or just the vacuum pulled air from the reservoir for a bit...
I'll upload pics in a minute.
Share this post
Link to post
Snagger    197
The air was probably already there - bubbles, then clear , then empty can only mean trapped air.  That is the whole point of vacuum bleeders rather than pressure bleeders - they suck out trapped air and are far more thorough.
How much did it cost?
Share this post
Link to post
Gazzar    31
40 GBP or so, eBay. Quite pleased so far. The job is a bit of a pig, too much corrosion everywhere, for my OCD, but it will get through the MOT. Once the lightweight is finished I will rebuild the 109 with a lot more zinc.
G.
Share this post
Link to post
Snagger    197
That is good.  I might get one myself.
Share this post
Link to post
Ally V8    17
G.
Good  for bleeding fuel filters on Freelander 2's too !
Share this post
Link to post
Dave W    29
I bought one of the Sealey vacuum things for my VW van for testing/exercising the turbo vanes. I've since used it for bleeding the brakes on my MKIII Sankey and will definitely be trying it out as an alternative to my Eezibleed next time one of the Land Rovers need their brakes bleeding.
Share this post
Link to post
western    211
G.
I fitted a low fluid float cap to my '89 110, I'll upload my wiring diagram, see post below :i-m_so_happy:
Share this post
Link to post
Davo    47
I've been using a weed sprayer for this job for years now. I added a low-pressure gauge, (just screwed into a hole in a thicker part of the plastic of the bottle), and put a hose fitting into a spare master cylinder cap, with a shut-off somewhere in the hose. For drum brakes, I found it's best to get the whole car onto stands, take off the wheels and drums, and put whatever works, (wire, clamps, etc.) onto the cylinders to keep the pistons compressed. Once the system is pressurised with the garden sprayer, it's easy and quick to go around to each wheel and bleed. But I will admit to not having done it for some time now!
Share this post
Link to post
western    211
Float cap & PDWA wiring as promised, quite easy to do, just find the connection on bulkhead that comes from PDWA & join to float cap with bullet connectors, if one or both fail the red brake fail light on dash will illuminate
Share this post
Link to post
Gazzar    31
I thought that would be the case, I just need to find the time.....
I've bled the system now, and aside from a new steel pipe that simply wouldn't seal, all is good. The Sealey system works. It needs an air connector to work, which isn't included, but with the different types available, that's fair enough.
Share this post
Link to post
zardos    6
I always wondered how these create a vacuum, looking at these pictures it seems it may be using the Venturi effect
From the manual is seems to use a lot of air (180 ltr/min) to create up to a 60% vacuum.
Share this post
Link to post
Gazzar    31
The compressor was working for sure, Clarke 3hp was running a lot.
Share this post
Link to post
HoSS    49
I have the Sealey one, and its certainly much better that the eazi-bleed. Vac vs pressure certainly get the air bubbles out better.
However mine recently fell down and broke the collection container off the gun so i need to replace.
I was looking at the hand pump type.
e.g. http://www.ebay.co.uk/itm/Bergen-hand-held-vacuum-pump-tester-brake-bleeder-B5202-/132179433969?hash=item1ec68219f1:g:yiQAAOSw3~tZbiST
Does anyone have any experience of those?
Share this post
Link to post
ballcock    30
They look simple enough to make out of paraffin/cleaner spray unit I have or an old paint spray gun. Although I don't understand why a vacuum system works any better than a pressure system as long as the fluid travels fast enough to carry any air with it and you don't allow any back in.
Share this post
Link to post
HoSS    49
It might be nothing in it, just my impression....
Although I have had the pressure cap pop off an eazi-bleed once making a bit of a mess, and theres always the risk of over-pressuring the resevoir. Vac is kinder in that respect.
Share this post
Link to post
Gazzar    31
Agreed, the reservoir on the 109 did creak worryingly when I last used the EziBleed.
G.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
