Replacement for Kenlowe 2 speed electronic thermostat ?
Defender90Dave
Does anyone know of a stockist for the Kenlowe Electronic thermostat with 2 temperature setpoints for 2 speed fans or if not a supplier of a replacement product. I have just found out mine is not working.
Any help would be appreciated as im really stuck on this one.
Regards,
Dave
  • Thanks 1
There's a 4-relay circuit a few of us on here use that makes use of standard 3-pin fan switches (Intermotor make them), it's most likely in the technical archive.
A variation on this is the Freelander 1 has the same circuit (4 relays) in a little black box under the bonnet - if it has two electric fans (I think aircon equipped ones do) you can find them, or they're around on ebay for about a tenner. The wiring is nicely documented in the RAVE manual electrical section.
Adjustable set-point I can't help with but the intermotor switches come in a range of values.
  • Thanks 1
