cj01 Posted September 6, 2017 Share Posted September 6, 2017 Hi guys looking for some help.My mates 300 110 engine and box are trashed.So we have got a complete disco td5 manual and are going to transplant it into the defender.Td5 and box fitting will be no problem plumbing and fuel no problem.Concerns are the ecu if we take all the gubbings out of the disco (electricity parts~) will we get it going?The donor disco is a 2001 model with a rotted chassis etc.Any help heads up will be appreciated. regards chris Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 7, 2017 Share Posted September 7, 2017 Disco gearstick will come out in the wrong place (assuming Td5 is same as the earlier discos). Wonder if the ECU can be made into a defender spec one so it's not looking for stuff like the BCM? Quote Link to comment Share on other sites More sharing options...
cj01 Posted September 8, 2017 Author Share Posted September 8, 2017 Hi Thanks for your reply.We thought this would be a simple transplant,should have thought a bit more!Its the ecu bcm thingy!Not quite up to modern electronis.Although have megasquirted my v8.I was hoping someone may know of a similar conversion with an ecu fix. Thanks again Quote Link to comment Share on other sites More sharing options...
