Troll Hunter Posted September 10, 2017 Share Posted September 10, 2017 Both front door locks on my vehicle are defective, one totally useless, ie inoperable, as opposed to being subject to tea spoon operation, and the other is intermittently so. The decision I need to make is whether I should order three barrels, one for each of the front side doors and the rear safari door, or should I order four barrels, and include the ignition lock. I would prefer to have a common key for both doors and ignition. My question is does the ignition lock have the same design barrel as the doors? I assume that the replacement lock barrels supplied by Paddocks provide the usual, ineffective, token LR security. Does anybody have experience and recommendation for an alternative, please? I prefer not to start modifying the doors, but if needs must ........ All responses, on either question will be very much appreciated, thank you. Mike Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted September 10, 2017 Share Posted September 10, 2017 Only 2002+ door locks can use the ignition key, due to the barrels being wider and longer. Unless you upgrade to these then it's always going to be 2 keys. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted September 10, 2017 Author Share Posted September 10, 2017 Thanks for your input, dailysleaze, but I still have the original door locks and ignition lock on my 1991 CSW and they're all the same key, so that's what made me ask. Does any other member have input, please? Mike Quote Link to comment Share on other sites More sharing options...
Litch Posted September 10, 2017 Share Posted September 10, 2017 “Only 2002+ door locks can use the ignition key, due to the barrels being wider and longer. Unless you upgrade to these then it's always going to be 2 keys.” Not so. My 300TDi used matching keys which I bought from SP Global Parts, long key with short barrel door-locks which fitted & worked perfectly (I say did because I have Optimill handles now which use a different type of lock entirely). I see that others now offer the same kit as SPG. Quote Link to comment Share on other sites More sharing options...
timc1967 Posted September 10, 2017 Share Posted September 10, 2017 18 minutes ago, Litch said: “Only 2002+ door locks can use the ignition key, due to the barrels being wider and longer. Unless you upgrade to these then it's always going to be 2 keys.” Not so. My 300TDi used matching keys which I bought from SP Global Parts, long key with short barrel door-locks which fitted & worked perfectly (I say did because I have Optimill handles now which use a different type of lock entirely). I see that others now offer the same kit as SPG. Optimil handles? Link please. Quote Link to comment Share on other sites More sharing options...
western Posted September 10, 2017 Share Posted September 10, 2017 just google optimil products http://optimillraceproducts.com/index.php?cPath=33&osCsid=7490f97cf41f62ee0d6cfc3b5e8cc163 hope your sitting down & got a firm hold on your piggy bank, cos when you see the prices, piggy bank will do a runner 2 Quote Link to comment Share on other sites More sharing options...
Litch Posted September 10, 2017 Share Posted September 10, 2017 There you go........................... http://optimillraceproducts.com/ As already stated, take a deep breath first. Got the door-handles and F&R hinges, not cheap but lovely pieces of kit. 1 Quote Link to comment Share on other sites More sharing options...
timc1967 Posted September 11, 2017 Share Posted September 11, 2017 That's a weird site - doesn't explicity state that these are pretty much all direct replacement Defender parts. Is that the case? Prices are high, but I can see its heavy duty, built to last; more so than OEM. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 11, 2017 Share Posted September 11, 2017 ... but I can see them wrecking the door if you catch them on a tree whilst laning unlike the weak plastic ones which just disappear 😁 Mo 1 Quote Link to comment Share on other sites More sharing options...
ShortTimers Posted September 12, 2017 Share Posted September 12, 2017 On 11/09/2017 at 10:55 AM, timc1967 said: That's a weird site - doesn't explicity state that these are pretty much all direct replacement Defender parts. Is that the case? Prices are high, but I can see its heavy duty, built to last; more so than OEM. They are direct replacements, I've fitted the bonnet hinges and I watched a guy swap the door handles on his truck and it seemed to fit with no problems or fettling needed. But as Mo said not great if you catch a tree as your likely to loose half the door before the handles give way... they are well made.... Quote Link to comment Share on other sites More sharing options...
easytiger Posted September 13, 2017 Share Posted September 13, 2017 I bought this set from sp4x4. https://www.sp-4x4.com/QRF100880_DEFENDER_IGNITION_LOCK_SET_p/qrf100880-3.htm it does get you away from the many key situation but I fear that it does little to boost security. Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 13, 2017 Share Posted September 13, 2017 I did something similar to easytiger, but I got the new door handles included too so I've got one key for front doors and ignition. More as a bit of a security upgrade. Quote Link to comment Share on other sites More sharing options...
=jon= Posted September 13, 2017 Share Posted September 13, 2017 I've also got the SPF locks on mine. Apparently they take the standard locks and file down the pins, so it's pot luck as to how well they work when re-keyed to the front half of the ignition key. A couple of mine work well, one you can open with any bit of metal approx the right size. If I was doing it again (and this is on the jobs board for the LR!) I'd remove / disconnect all of the lock barrels and rely on remote locking from the alarm, with the rear door as a keyed backup. I've already got the central locking so half the job is done, it just needs connecting up - but if you haven't you can get cheap remote locking kits from ebay for £30 or so. Quote Link to comment Share on other sites More sharing options...
