Ashwin Posted September 14, 2017 Share Posted September 14, 2017 Hi i have land rover dicovery 2td5. I has no pulling in low rev. But when its crose 1500rpm then its start pulling. Maf is new. aney one can help Quote Link to comment Share on other sites More sharing options...
ballcock Posted September 15, 2017 Share Posted September 15, 2017 Welcome Ashwin, I am not clued up on the TD5 engine but have you checked the basics? When was it last serviced? Do you use an injector cleaner? Is the timing correct? Hopefully some one more experienced may offer some help. Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted September 18, 2017 Share Posted September 18, 2017 Have you driven any other td5 Disco 2s for comparison - eg before you bought this one? 1500rpm is about where the standard set up turbo begins to boost noticeably. Below this they don't pull well! Could it be the behaviour is standard? Quote Link to comment Share on other sites More sharing options...
L90-v8 Posted September 19, 2017 Share Posted September 19, 2017 On 18/09/2017 at 12:22 PM, Pawl12 said: Have you driven any other td5 Disco 2s for comparison - eg before you bought this one? 1500rpm is about where the standard set up turbo begins to boost noticeably. Below this they don't pull well! Could it be the behaviour is standard? same as mine goes fine when its on boost Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 20, 2017 Share Posted September 20, 2017 Find someone with a nanocom and get her plugged in to see if anything is popping up on the fault list. Quote Link to comment Share on other sites More sharing options...
