Prop shaft
jordan_meakin
From the LR Workshop Manual: "A total of .004" (0,1mm) of circumferential movement, measured on the outside diameter of the splines, should not be exceeded. If wear beyond this limit has taken place, a new propeller shaft complete must be fitted."
Mind to wash the parts before measuring as grease will hide a lot of play easily.
