What tool for setting the Swivels
Cornish Rattler
Honestly.... I use 'feel'.
If it flops from one side to the other and/or rattles - Too loose
Actually quite tough to turn by hand - too tight.
I've set stuff up to spec before and have had to pull it apart again to do it by feel to make it right.
I bought a little spring scale on eBay. They are just a few £. If you do buy one just make sure that you pick one with a small range. Don't get a 50Kg span as then you definitely can't pull and hold whilst trying to tighten.
Went I first did mine, I had no idea how sensitive the steering would be to this setting but I think as Bowie says, it's probably not that much!
Ditto ^^^
I've never had much luck adjusting them with a spring balance. Generally they end up too loose when done that way.
(Now reminding myself that the 110's swivels need tightening up.)
