need4speed
New Defender
The factory is being built in Slovakia.
I had the opportunity to discuss with a few people involved in the project and although they were careful not to say anything precise, one told me I should expect to be positively surprised.
Wait and see...
Share this post
Link to post
The off-road trials have being going on and I am led to believe the road trials are in progress so keep your eye out...
Share this post
Link to post
3rd April... 2018...
Share this post
Link to post
I quite like that!! Slightly longer than I'd desire but I'm sure with a few adjustments the break over could be improved....
Share this post
Link to post
Its the Supacat LRV400. It could be marketed with optional grp top body. Lan Rover, like with the RR in 1970, will create a new market niche: the MegaUTV.
Share this post
Link to post
Simple - heavier right foot to clear the obstacle. Similar power and torque figures to a 3.6TDV8 and 200kg lighter 'depending on configuration'.
Share this post
Link to post
Well a friend's Dad works for JLR and has knowledge of the Defender replacement. Now he knows my love of the defender and what it stands for and in his words 'I think you'll like it'. So will have to wait and see. He wouldn't give me any info when pressed sadly :P
  • Haha 1
Share this post
Link to post
No no no no its just too long !
The best place for anything that long is in a canal.
Mo
  • Haha 3
Share this post
Link to post
Mo
:lol::rofl:
Share this post
Link to post
That supacat has a strangely alluring look....Ewok lights and clamshell bonnet but still makes me think of a Toyota Land Cruiser...must be going mad.
Share this post
Link to post
Doesn't look that terrible, mix of disco and defender, I think?
Share this post
Link to post
Sorry but that looks like the person I'm not that keen on love child of a mk1 LWB shogun and a fiat panda.
yuk!
  • Like 2
Share this post
Link to post
Haha, swear filter didn't like my use of the common word for questionable parentage starting with "b" and ending 'stard lol
Share this post
Link to post
On 12/10/2017 at 3:58 PM, o_teunico said:
MoD aready has its own Defener replacent...McGovern style front end included!
I have to say I quite like that to as for length mo it's not what you have its what you can beat it into.....
Mike
Share this post
Link to post
It is interesting to read that "For the ‘Mk 2’ LRV, Supacat have taken the rolling chassis and automotive systems from the Land Rover Discovery and adapted them for specialist military applications."
Spec are "permanent 4WD with centre diff. lock Differentials Options including : Front and rear air locking Suspension and axles Front and rear fully independent double wishbone".
I wonder what land rover could do with the Discovery rolling chassis if Supacat have done this?
Share this post
Link to post
It would be nice to steer this thread towards some actual positive forward-looking discussion of what land Rover might actually really do with the new Defender.
The Supacat thing certainly shows the sort of thing that's possible, and the D3/D4 platform is incredibly capable even if (in its more luxurious form) it adds a lot of complexity. BUT -  strip out some of the gizmos, put it on coil springs and you've got a sturdy high-articulation independent modern 4WD platform.
The TATA Sumo looks fugly/cheap but I doubt LR would sell anything like that, certainly they'd give it a trip through the styling department before putting the green oval on it.
Share this post
Link to post
You'd lose quite a bit of it's flexibility then.
In my opinion one of the most significant benefits of using the air bags is Land Rover's cross-linking of the bags - in short you the benefits of fully independent suspension when on-road and then the benefits of a live axle when off road.
Longer version for those that aren't aware (based of my L322 but I'm sure the Disco is the same setup):
Basically when 'Special Programs' are off on the valves between bags on the front and rear axles are closed. This means when you hit a pothole (for example) only the wheel that hits it is affected. If you have a live axle then some 'shock' is transmitted through the axle to the other wheel. I've experienced this in the Defender when you hit big pot holes whilst cornering the front can jump sideways. With independent suspension it doesn't happen (drove over the same pothole in Waterlooville in both Defender and TDV8).
When you activate the terrain response (maybe only in some modes not all) a valve opens between the air bags on each axle. This means that when one wheel gets pushed up, by say a rock, the air flows to the other bag pushing it down just as a live axle would. If you didn't have this valve then the air bag on the rock would compress and all you'd likely do is lose ground clearance as the middle of the vehicle stays flat.
It also has obvious benefits that you can adjust the ride height for on-road stability. E.g. the TDV8 will hunker down ~1" if I remember correctly if you go over 100mph and stay above 80mph afterwards. Reduces some drag but also makes the vehicle more planted.
Share this post
Link to post
Evidently it has coil springs and airbags and it has some quite individual off-road characteristics.
Share this post
Link to post
That's it.... tease us Mav!
Regardles of what appears it will be loved and loathed with equal aplomb.
Share this post
Link to post
Ed - you're right that EAS has many advantages, but there will be a crowd who want the simplest/cheapest possible vehicle so I can well imagine the "base" model might have coils, much like some of the low-end D3's did.
Share this post
Link to post
