ianmayco68 Posted October 4, 2017 Share Posted October 4, 2017 Hi all , looking for some advice on whether to spend or save me money, as above on my new project I'm converting it to an auto it will only be used for road work and maybe going down a track or two . So to my question ,would converting it to vented discs have any benefit or would I just be converting for the sake of it ? All opinions and advice welcome the more the better ,anyone who's done this conversion was it worth it ? cheers Ian Quote Link to comment Share on other sites More sharing options...
Tanuki Posted October 4, 2017 Share Posted October 4, 2017 With an auto you get much less engine-braking effect so you'll end up using the brakes more. So vented discs would definitely be worth thinking about, specially if you plan on doing any towing. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 4, 2017 Author Share Posted October 4, 2017 That was my thinking , she won’t be used for towing I’ve got my 110 for that and any off roading I do. Would you do just the fronts ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 4, 2017 Share Posted October 4, 2017 You can't fit vented discs to the back, at least not easily Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 4, 2017 Author Share Posted October 4, 2017 Right vented front and solid rear it is then Quote Link to comment Share on other sites More sharing options...
Arjan Posted October 4, 2017 Share Posted October 4, 2017 We had a 110 CSW with Mazda 3.5 Tdi & ZF Autobox and ran it everywhere. Standard 4 discs and never any problems. TBH, bit of a waste. Quality discs & pads should be more than up to the job. Quote Link to comment Share on other sites More sharing options...
PaulN Posted October 4, 2017 Share Posted October 4, 2017 Ours is a 300tdi 90 on with solid discs all round and an auto - stops well. Can lock up in the wet and greasy! Only thing needed is rather more servo assistance than the original servo and master - one of my upgrades to do. You'll use the auto box down to 3 and 2 for extra braking when needed anyway. Save your money for fully operable calipers and quality discs and pads - more than good enough! IMO. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 4, 2017 Author Share Posted October 4, 2017 Cheers all I like the sound of saving money to spend else where . What do you mean by upgrade the servo and master Paul ? Fit new ones or change them in some way ? Quote Link to comment Share on other sites More sharing options...
PaulN Posted October 5, 2017 Share Posted October 5, 2017 Update both as mine still has the original 1988 ones from when it had a 21/4 engine and whilst it all works could do with a little more assistace and less effort on my part....more of a modern car effort where you dont take heel off the floor! So I am looking to check /overhaul the system and then replace pedal box and master cyl and servo with a 300 tdi one or mebee try the later abs version. My plan anyway - just need time - but as I say good quality standard brake components work very well..... Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 5, 2017 Author Share Posted October 5, 2017 Cheers Paul. Quote Link to comment Share on other sites More sharing options...
