mcc1979ian Posted October 4, 2017 Share Posted October 4, 2017 Evening gents. In abit of a dilemma. My current bulkhead o. My 1986 90 is in abit of a state and I'm in 2 minds whether to repair or replace. I was ment to be buying a decent td5 one for £200 but for the past month haven't been able to get through to the guy 😡😡 so now my options are look for another or repair mine. Basically both top corners have started to go I. The last month or so, also the passenger footwell has had a plate welded in and when you lift the driver mat you can see outside. My welding isn't great but I get by so would I be best to repair or replace or does anyone know someone e who might can repair it for me. Cheers Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted October 5, 2017 Share Posted October 5, 2017 These are the bits? You might manage it with basic welding skills. Link: https://yrmit.co.uk/product/rhs-extended-bulkhead-repair-panels-land-rover-defender-series-23/ Quote Link to comment Share on other sites More sharing options...
Arjan Posted October 5, 2017 Share Posted October 5, 2017 Any replacement bulkheads, no matter how good looking, will find places that need work before fitting - you may want to consider galvanizing the thing as they are a @#$@# to take out and refit... By the sound of it, yours is repairable. Bon Courage ! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 5, 2017 Share Posted October 5, 2017 I'd have a go at repairing yours. Mine was in terrible shape with rusty top corners and a good proportion of both footwells beyond saving. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted October 5, 2017 Share Posted October 5, 2017 Doesn't sound too far gone, it's a time and effort affair for repairing them. Just purchased a set of repair panels to do a td5 one (extended as listed above), I've also ordered the newly available full vent panels (YRM don't list them, they have corner repairs or vent removal sections). The top corner and vent areas are the hardest to get an invisible repair albeit it depends how far gone your corners are...you may be able to cut out the rust and replace with fresh steel. The footwells are a mainly spot welded in, if you have access to welding gear give it a go...doing numerous plug welds is great practice. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted October 6, 2017 Share Posted October 6, 2017 I agree with Scotts90. If you've got the time, go for it. I'm currently repairing my bulkhead, which wasn't in too bad a condition, Both footwells needed patching and small areas on both sides at the top. I'm using 20ga sheet, minimum power setting on my MIG welder with a slightly faster wire feed than recommended. I find this allows me to bridge the gaps without inputting too much heat and blowing through the sheet. My bulkhead will be galved, along with the chassis and many other smaller parts, when I finish the repairs. Bowie69 sent me this vid a couple of days ago, and it's improved my welding tremendously. I hope you get the same benefit. On 10/1/2017 at 10:51 AM, Bowie69 said: @Troll Hunter, watch this, it is a technique I use a LOT on sheet metalwork to great effect (thinner stuff than LR bulkhead too): Mike Quote Link to comment Share on other sites More sharing options...
Paddy Posted October 6, 2017 Share Posted October 6, 2017 Pinched from a previous thread https://www.shielderchassis.com/shop?olsPage=products&olsFocus=false See bottom of the page, might be an option thats worth a phone call, if you can wait and have the money. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted October 6, 2017 Author Share Posted October 6, 2017 Cheers fellas. Will most likely take your advice and repair it and send to the galvanisers. I have a td5 one adapted to tdi already galved and primed but I need that for my other project or I'd rob it. Best brush up on my welding skills Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 6, 2017 Share Posted October 6, 2017 Where abouts are you based? (I'm on mobile so I can't see it) I'm sure someone on here would be happy to help show you the ropes on the welding? I'd be happy if you're anywhere near SN7. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted October 11, 2017 Author Share Posted October 11, 2017 Scottish Borders. Iv got a mate that leads us to believe is a coded welder that I was gona ask to come round and give me tips then I got him to weld on my crossmember and iv suddenly changed my mind 🤔 Quote Link to comment Share on other sites More sharing options...
Maverik Posted October 12, 2017 Share Posted October 12, 2017 I replaced my 86 bulkhead with a 2002 td5 one 5yrs ago now, but I didn't have the funds or skills to get it galvanised, I know of at least one hole already that has appeared and its showing signs in other places too, quite disheartening, but on the plus side I have another brand new bulkhead I'll be getting shot blasted and galvanised quite soon and that will be going in the back pocket for the next re-build... Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted October 12, 2017 Author Share Posted October 12, 2017 Once mine repaired it will definetly be making a trip to the galvanisers. Got the one on my 84' done and it came back spot on so worthwhile doing again. Just the inside will need a good soaking in cavity wax Quote Link to comment Share on other sites More sharing options...
