Are wheel arch spats handed?
I’m planning to refit the OE arch spats having removed them years ago to fit wider ones and now that I come to reuse them for something I can’t remember which was which. I’ve sussed our the fronts but I can’t decide if the rears are handed, and if so how to tell them apart. My tub is quite rough and bruised so it’s of little use as a template.
Can any knowledgeable members help out with some info?
Much appreciated, Lewis
The front arches as you said are handed, they are slightly longer on the rear edge so that they meet the sill. The rears are the same part number for left or right 1986-2006 although the part numbers vary dependent on pre/post 2006. Must admit I can't see the difference comparing a 2013 110 at work with my 2005 110.
https://www.britishparts.co.uk/products/8829-wheel-arch-eyebrow-ALO710010
Hope that helps, Harry
Edited by Boris113
typo
