Ali Zafar Posted October 10, 2017 Share Posted October 10, 2017 So I didn't secure the battery and the positive battery terminal hit the front wall of the battery box when I went over a bump. I heard a loud shrill noise from under me(LHD) and the engine died. The picture is after I have re positioned the terminal on the battery. Does that mean the ecu is shot? I dont hear the fuel pump and no glow plugs indication on the cluster. I disconnected the ECU and I still have the same number of lights going off on the cluster as with the ecu connected. Is there a way to check the ecu? I checked ALL the fuses and they are fine. Its a 2001 10p TD5 Defender 110. ECU MSB000080 Is there a way to confirm if the ecu is dead? And if it is, what are my options? I am based in Islamabad Pakistan and an ECU, NNN500020 is available to me can I use that I am not sure which vehicle it is from. Appreciate your help! Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted October 10, 2017 Share Posted October 10, 2017 Check the fuel inertia switch on the bulkhead under the bonnet. It's designed to turn off in an accident and a large bump can trigger it Quote Link to comment Share on other sites More sharing options...
Ali Zafar Posted October 11, 2017 Author Share Posted October 11, 2017 8 hours ago, dailysleaze said: Check the fuel inertia switch on the bulkhead under the bonnet. It's designed to turn off in an accident and a large bump can trigger it Already checked that a couple of times! Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted October 11, 2017 Share Posted October 11, 2017 In your situation all you can do is to get the wiring diagram and check all the feeds and earths to the ECU.Did the car use alarm fobs,if it did the chances are the engine ECU will be set to robust immobilisation.The NNN50020 ecu would be fine,but you would probably need to use a diagnostic tool such as Nanocom to do a security relearn.To just prove the ecu you don't need to worry about injector codes,the security learn is enough to run it.Without diagnostic kit if you plug the NNN unit in you will probably find it will crank,fire a few times,then die. Quote Link to comment Share on other sites More sharing options...
Ali Zafar Posted October 11, 2017 Author Share Posted October 11, 2017 I don't have an immobilizer. I have a standard all metal key. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted October 11, 2017 Share Posted October 11, 2017 Ok, but the car is still likely to have an alarm/immobilser ecu - the green Lucas 10 10AS unit.(Google it for pics,located behind the dash on RHD,can't remember on LHD) If you are very lucky the NNN unit you say you have may not be set to robust immobilisation,in which case the car should start and run.(Assuming thats all thats wrong) If it is set to Robust then you will need to do a security relearn with Nanocom or similar to get it to go. It would be good to hook up a Nanocom anyway,see if the old ECU is awake,see what live data you can get from it.You can also read the injector codes from it to input into the new init if you need to. Quote Link to comment Share on other sites More sharing options...
