Pinion seal
jordan_meakin
Well, no luck. Couldn't get the sodding crown nut off. Firstly, someone had kindly tried before but failed to remove the split pin, leaving it stuck in with nothing to get hold of to pull it out. Great. Any ideas? I'm thinking it'll need cutting off but it's bloody awkward round there for a grinder.
Drill out the split pin, its only soft metal. If the nut is still stuck, use a jack under the spanner to take up the slack in the diff ( with the wheels chocked or the brake pedal wedged down) and then belt the spanner with a lump hammer - works every time.
