James NZ Posted October 13, 2017 Share Posted October 13, 2017 Hi all, Hopefully this is the right forum, if not could the mods please either move or delete as required. I bought some LED fog/daylight running lights that were advertised as fitting the disco 3 from a chinese site. I don't have a disco 3 but my intention is to fit a pair of lights into my home made winch bumpers, for two discos. I need to ID the plugs which I've tried but aren't getting anywhere. The dimensions of 21.4mm x 12mm are inside the plug and externally it measures 24mm x 14.5mm. It has two connections with the number 11 cast into the base on the left and 8 on the right. There are three locating lugs externally and a dividing moulded bit inside the plug. Also does anyone know what the terminal numbers refer too, like ground or supply? The terminal 11 has a white wire which I'm guessing is supply and terminal 8 is black, so earth? I checked the Bosch terminal codes but those no.s aren't listed. The other two photo's are so you get an idea of what it looks like. If I can't get a plug I'll fit small terminals and then encapsulate them in some epoxy. But I'll need a plug somewhere and on the light fitting would be nice. Thanks guys, James NZ Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted October 14, 2017 Share Posted October 14, 2017 Looks like a standard h11 bulb connector ... http://www.ebay.co.uk/itm/H11-H8-Ceramic-Bulb-Holder-2x-Socket-Connector/261904224719?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D46150%26meid%3D2a0c0cef46204c40a986c99f7cb3cff2%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D172084076840&_trksid=p2047675.c100005.m1851 not to be confused with an h9 as it has two dividers in the plug rather than one Quote Link to comment Share on other sites More sharing options...
zardos Posted October 14, 2017 Share Posted October 14, 2017 or a more local link https://www.trademe.co.nz/motors/car-parts-accessories/performance/bulbs/auction-1439286853.htm Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted October 14, 2017 Share Posted October 14, 2017 Well I did assume once identified that he’d source a local one. Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted October 16, 2017 Share Posted October 16, 2017 They look a lot like the ones discussed in this thread about indicator side repeaters. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted October 16, 2017 Share Posted October 16, 2017 The ones in question have two external guides plus the lock latch and the central divider. Different from the td5 indicator plugs in the link. Quote Link to comment Share on other sites More sharing options...
James NZ Posted October 20, 2017 Author Share Posted October 20, 2017 Hi guys, thank you to Scotts90 for identifying the plug and to zardos for the local link. I ordered from the local source, they arrived yesterday and now I have working lights. Best I get on and finish the bumper to mount them then. Cheers guys, James NZ Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted October 21, 2017 Share Posted October 21, 2017 Cool. Glad to help Quote Link to comment Share on other sites More sharing options...
